Whining noise in 2000 Accord
Old Jan 27, 2008 | 05:14 PM
migoo33's Avatar
Default Whining noise in 2000 Accord
My wife's car just recently started making a whining noise when it is moving. It only makes this noise as the car is moving. As the brake is applied, the noise fades and goes away when stopped. It does not make this noise when idleing or being revved up. It sounds like it is coming from the front passenger side wheel area.
Any ideas/suggestions?
Old Jan 27, 2008 | 05:19 PM
Tyte-S's Avatar
Default Re: Whining noise in 2000 Accord (migoo33)
Does it get louder if you turn the steering wheel?
Old Jan 27, 2008 | 05:34 PM
YeuEmMaiMai's Avatar
is it an auto? does it leak at the axle seals? if so you are expletiveed.....it's most likely the differential
Old Jan 28, 2008 | 06:27 AM
migoo33's Avatar
Default Re: Whining noise in 2000 Accord (YeuEmMaiMai)
The noise does not change when the wheel is turned. Only when making a turn because the brake is being pressed.
It is an automatic and I haven't noticed any leaking at all.
Thanks for your input so far.
Old Jan 28, 2008 | 03:10 PM
when the differential bearings wear it whines and usually the axle seals leak. put the car up on a hoist or ramps and take a look
Old Jan 29, 2008 | 04:52 AM
migoo33's Avatar
She actually said that the noise lasted for less than a minute yesterday and she drove it for about 65 miles total. Any other ideas? Thanks
Old Jan 29, 2008 | 02:55 PM
alt? those things are a POS I had bearings fry on my 98 V6 alt.......3 days before it died it made a whining noise for a few moments.......
curvenut
Jun 17, 2014 12:32 AM
edu-dba@hotmail
Aug 21, 2013 01:25 AM
Geoshanna
May 20, 2013 07:27 AM
vigorhy
Mar 20, 2008 03:54 PM
mstewar
Nov 21, 2002 12:54 PM
