Injectors wont open no Grounds....
Old Jan 27, 2008 | 11:04 AM
JdmFr0g's Avatar
Default Injectors wont open
first off the car is an ef sedan lx was converted from dpfi to mpfi and im using a jumper harness from boomslang obd0 - obd1 the motor is an b17a1 .... the car turns over and gets spark the injectors are not pulsing ... from my troubleshooting i see that there is a ground on the harness that i guess bolts to the thermo water neck... from the engine harness (bty i didnt wire the car) they injector get 12v at the ecu KOEO can i jus run all the power grounds and logic grounds from the ecu.. pins A23-A26 (obd1) straight to ground at the battery.?.... the car sounds like it wants to run but the injector arent pusling they have voltage though...
Modified by JdmFr0g at 12:22 PM 1/27/2008
Old Aug 9, 2008 | 10:19 PM
dohccrxsi's Avatar
Default Re: Injectors wont open (JdmFr0g)
check firing order from dizzy to sparkplugs
89ED
Jan 28, 2019 01:11 PM
smokeyjpn221
Apr 21, 2010 06:29 PM
zenon8890
Oct 13, 2009 04:00 PM
A train
Oct 22, 2008 04:20 PM
crx_si-r
Jun 24, 2008 02:05 PM
