-running right?
Old Jan 27, 2008 | 10:49 AM
whats_vtec's Avatar
Default -running right?
ok guys...i have a 93 civic ex with a d15b non-vtec motor that i just installed..(z6 had a blown HG and this motor tranny combo was CHEAP..) the motor came from a SOL.
this is how its running:
Power is lacking terribly until 3.5k then it kicks in and actually feels like vtec..and it pulls pretty hard to 5.5k in first then it feels like its lacking fuel..it kinda stutters till i shift to second...second will go up to 6-6.5 without sputtering.. i ran a 16.7 in my Z6 and this new motor when you are winding it out actually feels just as powerful. bUT Only after 3.5 does it have ANY grunt to it....does that sound right for this d15b?
it shouldnt be stuttering that early in the rpms, right?
another thing..if its usefull info....the exhaust manifold is the one off the Z6..could that affect it?
i was thinking maybe fuel filter, o2 sensor for the sputtering..not really sure?? any other suggestions?
I run of off 24 kbps..so searching is difficult where im at..
Old Jan 27, 2008 | 11:39 AM
duefuss's Avatar
Default Re: -running right? (whats_vtec)
which ecu are you using?
Old Jan 27, 2008 | 12:04 PM
whats_vtec's Avatar
Default Re: -running right? (duefuss)
the motor tranny combo came with a p06...ive read the my p28 would work , but it would run rich...which could be bad, correct?
Old Jan 27, 2008 | 04:31 PM
duefuss's Avatar
running rich bad.. yes. running lean even worst.... it could be any number of things what CEL codes are you throwing if any? also make sure you have no vaccume leaks.
Old Jan 28, 2008 | 02:11 AM
whats_vtec's Avatar
its not throwing any codes...im also running a straight pipe..no resonator or cat..
Old Jan 28, 2008 | 04:51 PM
duefuss's Avatar
vaccume leaks???
dynamatt
Honda CR-V & Element
12
Sep 14, 2016 07:57 AM
just.me.ek5
Dec 11, 2008 10:59 AM
EG6[B16A1]
Oct 31, 2003 07:43 AM
Charlie Moua
May 17, 2002 03:11 PM
