Inside the V6 Automatic Transmission
Old Jan 27, 2008 | 09:20 AM
Jim Truett's Avatar
Default Inside the V6 Automatic Transmission
It's a 1999 V6 Acura CL tranny, but the case and internals are pretty much identical to the Accord V6. It's basically just like a constant mesh manual tranny with hydraulic clutch packs to select the gears. This transmission started slipping badly on a 2nd and 3rd shift. The 2nd gear clutches were worn down to the adhesive that bonds the friction material to the clutch plate. Normal thickness was .079", and these measured in at .055-.050". The standard free play in the clutch packs is between .015"-.045". With six discs worn between .024"-.029", that combined for about .160" total free play, and made the shifts very harsh.
With the end cover removed:
With the mid case removed:
1/2 clutch drum with clutches removed:
Worn 2nd gear clutches:
Installation of new friction and steel:
Old Jan 27, 2008 | 01:11 PM
-RedneckDave-'s Avatar
Working
Default Re: Inside the V6 Automatic Transmission (Jim Truett)
This is going right into the FAQ. This is very nice.
Old Jan 27, 2008 | 03:41 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Inside the V6 Automatic Transmission (-RedneckDave-)
Very brave
Excellent post though
Old Jan 27, 2008 | 03:44 PM
02 accord's Avatar
How many miles were on that?
Old Jan 27, 2008 | 04:51 PM
Jim Truett's Avatar
Default Re: Inside the V6 Automatic Transmission (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">How many miles were on that?</TD></TR></TABLE>
111,561. I would not have gotten much more out of 2nd gear.
Old Jan 27, 2008 | 05:09 PM
YeuEmMaiMai's Avatar
hey did you pull the internal mesh filter when you put that pos back together?
Old Jan 27, 2008 | 05:18 PM
Jim Truett's Avatar
Default Re: Inside the V6 Automatic Transmission (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">hey did you pull the internal mesh filter when you put that pos back together?</TD></TR></TABLE>
I checked it out. It was suprisingly clean. It's not much of a "filter".
Old Jan 27, 2008 | 05:22 PM
gianinline's Avatar
Default Re: Inside the V6 Automatic Transmission (213374U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 213374U &raquo;</TD></TR><TR><TD CLASS="quote"> Very brave
lol... something with transmission gears and the way they have to be assembled... few people would want to work on that.
Old Jan 27, 2008 | 05:33 PM
GL with that man I had a 98 LX V6 coupe that ate 3 transmissions within 11K miles........
Old Jan 27, 2008 | 08:42 PM
RS2 FAB's Avatar
Old Jan 27, 2008 | 11:55 PM
djphonics's Avatar
Default Re: Inside the V6 Automatic Transmission (RS2 FAB)
111k is the life I'd expect to see out of an auto tranny in a Ford, but not a Honda. That's disappointing.
Cool pics though. I would personally be terrified about taking an auto apart. Those babys are complicated.
Old Feb 3, 2008 | 09:59 AM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">GL with that man I had a 98 LX V6 coupe that ate 3 transmissions within 11K miles........</TD></TR></TABLE>
This is the reason I chose to rebuild it myself. When you have someone else do it, you don't know how competent they are. Also, when you get a reman from Honda, there is no way to tell what the original failure was.
My failure was from the previous owner not changing the fluid per the service guidelines.
Old Mar 18, 2008 | 06:57 PM
xci_ed6's Avatar
so that was it???? Just dropped in some new 2nd gear discs and steels and slapped 'er back together?
Any other parts that you replaced/noticed/would recommend replacing?
I worked for Honda, but we never open trans cases. Just put the onld one back in the box the new one came from :D
Old Mar 18, 2008 | 08:14 PM
did you inspect the differential bearings.....those things are crappy as can be.......
I am suprised that the internal filter was clean but the 2nd gear clutch pack was toasted......
Old Apr 1, 2008 | 03:32 PM
fleetw00d's Avatar
Is it only the V6 automatics that have this kind of trouble? Got a friend looking for a 5th-6th generation automatic Accord for his wife. Want to let him know what to avoid.
Old Apr 1, 2008 | 03:37 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Inside the V6 Automatic Transmission (fleetw00d)
mainly it's the 98-02 V6 auto's IIRC.
Old Apr 1, 2008 | 07:11 PM
Legendaryyaj's Avatar
Default Re: Inside the V6 Automatic Transmission (TouringAccord)
Avoid the TL's and CL's as well.
Old Nov 13, 2008 | 11:14 PM
JHern's Avatar
Thanks for posting these great pics. I have a 2001 Accord V6 with 98k miles. The tranny is not slipping between gears, but the shift from 1st to 2nd gear is a bit sudden (dropping from just above 3000 RPM to 2000 RPM during the shift) when accelerating from a stop. A Honda mechanic told me it is not a problem, and if it were a light would come on (is this true?).
It is not really bothersome, but I am beginning to think that I will have to get a transmission rebuild done on it some day. Frequent fluid changes will probably help prolong its life, I'm guessing. I also need to check that it is shifting at the proper RPMs.
But I'd also like to defend this car. It is really very nice. For us, a little tranny trouble, though considered a major repair, is worth it. Other than that, this car is fantastic. Great acceleration, wonderful ride, and solid construction all-around make this a great auto.
Of course, if things start to look worse, I might sell it before it gets to the point of no return if I ever change my mind on how much I love the car. This model has a great resale value.
Old Nov 14, 2008 | 08:32 PM
csmiths98AV6's Avatar
ah yes the good ol j30a1 auto matic tranny. ive had 4 in my accord, just bc of bs and im only supposed to be on 2 but..... yea mine went out at 160k which was really really surprising compared to alot of other accord owners. but yes these trannies are not very strong, and that is awesome that you are rebuilding it yourself
Old Apr 5, 2009 | 10:50 PM
bsivoljr's Avatar
cool man hey how do you know what to look for inside of this gearbox?
More specifically how do you recognize the wear or distinguish it. To a noobs eyes those clutch plates looked normal to me, key word noob but lets not focus on that too much lol. Peace Good stuff
'The engine made me do it'- EviL GeniUs
Old May 13, 2009 | 04:41 PM
tabahop's Avatar
New User
by the way seizing the opp..my tranny is all burnt out and im rebuilding it as you read this, the other problem i found on this tranny is one of the differential bearings is completely damaged and the carter has a little play with the steady part of the bearing...do you know if there's any method to adjust de free play of the differential?
Old May 14, 2009 | 03:11 PM
tabahop's Avatar
New User
by the way...do you reccomend an external cooler?
Old Jan 8, 2010 | 02:22 AM
Accord&Odyssey's Avatar
New User
Just curious, how do you refill the automatic transmission after you drain its fluid? I need to change out the ATF on my 2000 Accord V6 EX pretty soon but don't know where the refill hole/plug is. I really don't want to refill through the dipstick hole since I won't know exactly how much fluid is going in there.
Old Jan 8, 2010 | 04:35 AM
tamadrummer1120's Avatar
that is how you have to do it. unfortunately.....
Good thread!! I always enjoyed auto transmission rebuilds more than manuals for some reason. I guess just easier to work with.
Old Feb 8, 2010 | 09:56 AM
hary4925's Avatar
New User
I had a question for you. I am currently in the process of rebuilding this same transmission only mine is out of a 2000 honda accord ex v6 i have it completly out of the car now was wondering if you had any idea of where i can find torque specs for the case and the internal nuts for three gears. Also if you know of any other specs i would need that would be great. Thanks Harry
