accord type r
Old Jan 27, 2008 | 08:40 AM
atrhui's Avatar
Default accord type r
hey guys im new to the site and am a dedicated honda owner
i wanted to ask the wisdow of the site if anyone knows ?
i driva a 99 accord type r ( h22a7 ) and was looking to change the intake manifold and trottle body to aftermarket skunk2 products
i found that they do the parts for a h22 prelude and was wondering if they can be used on my own ??
secoundly i have a engine code p1399 and from my searches i have found that honda reckon it is a clogged egr valve port but i have cleaned it out put a new egr on ,ive changed the distributor cap and rotor arm new leads plugs serviced the engine and i still have this code in a pending state . it is not affecting the drive but the damn light keeps coming on .
any help would be cool thanks
looking forward to getting to know you guys !
Old Jan 27, 2008 | 08:47 AM
TheMuffinMan's Avatar
He knows where you live!
NOOOOOOOOOOOOOO
Skunk2 stuff is crap compared to your STOCK Euro-R manifold. And people have reported LOSS in power from them.
Believe me, people love the Euro-R's IM keep it and you literally have the best.
As to the code:
Have you cleaned out the EGR Ports?
Old Jan 28, 2008 | 02:45 PM
atrhui's Avatar
Default Re: (TheMuffinMan)
yeah i cleaned it out but the same code any other suggestions
Old Jan 28, 2008 | 04:04 PM
You cleaned out the EGR ports on the IM? (all 4 of them)
You may need to reset the ECU and clear the code to see if it pops back up
Old Feb 3, 2008 | 05:00 PM
atrhui's Avatar
i have taken off the egr and replaced it . changed the seals and rings ,cleared the port chamber and cover , and im still getting the same codes
Old Feb 4, 2008 | 05:27 AM
Hmm, dunno what to tell you, my suggestion (easiest probably)
Do a EGR delete, check out Rosko Racing (hit up google) they modify the Euro R manifold for us USA people but all the blockoff plates would work for you.
I believe they make a EGR/IACV one and a few others. All of which they sell separately.
Old Feb 4, 2008 | 11:13 AM
kulrevon's Avatar
If his car is a true euro R which it sounds like it is. He needs the egr for the obd2.
The egr delete is mostly for the people who want to run obd1 and its easier to trick the computer.
Old Feb 4, 2008 | 03:35 PM
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">If his car is a true euro R which it sounds like it is. He needs the egr for the obd2.
The egr delete is mostly for the people who want to run obd1 and its easier to trick the computer. </TD></TR></TABLE>
Ah interesting, I was unaware of that, thanks kulrevon.
Old Feb 4, 2008 | 04:31 PM
SkimN's Avatar
did you reset the ecu after you serviced it.
I think you just pull the battery fuse for 10 seconds, someone else chime in if I'm incorrect
rmiv1985
Jun 27, 2019 04:10 AM
Qi Jiang
Jan 28, 2017 07:25 PM
sussnk
Feb 27, 2015 03:52 PM
david017
Jun 19, 2014 03:36 PM
FF DRFT
Acura TSX
Jun 16, 2004 02:16 PM
