Check engine light!? (evaporated emissions system leak detected)????
Old Jan 27, 2008 | 04:09 AM
importknight's Avatar
Default Check engine light!? (evaporated emissions system leak detected)????
yea so i started up the R this morning and bam CEL, i did the paperclip method and got 90 which is evaporated emissions system leak detected? wtf is that? please help
Old Jan 27, 2008 | 05:48 AM
The Dude's Avatar
Banned
Default Re: Check engine light!? (evaporated emissions system leak detected)???? (importknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importknight &raquo;</TD></TR><TR><TD CLASS="quote">yea so i started up the R this morning and bam CEL, i did the paperclip method and got 90 which is evaporated emissions system leak detected? wtf is that? please help</TD></TR></TABLE>
Did you tighten your gas cap properly? Check all lines to Charcol canister.
Old Jan 27, 2008 | 08:08 AM
charcol canister?
Old Jan 27, 2008 | 08:14 AM
get RIGHT's Avatar
Default Re: (importknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importknight &raquo;</TD></TR><TR><TD CLASS="quote">charcol canister?</TD></TR></TABLE>
evap.
Old Jan 27, 2008 | 08:57 AM
u guys gotta help me out alittle more, i got no clue where the evap is, and my gas cap is on
Old Jan 27, 2008 | 09:48 AM
n1_egsex's Avatar
* B A N N E D *
its' under your battery tray, it's like a black oval shaped plastic can with a brown tube coming out the top and a plug on it, thats the best i can describe it as without taking a pic of mine
Old Jan 27, 2008 | 10:29 AM
ok thx alot im gonna check
Old Jan 27, 2008 | 03:43 PM
nope everything there looks it good shape nothing leaking, could it be cause my car is almost on Empty?
Old Jan 27, 2008 | 03:46 PM
Comp97GSR's Avatar
Sounds like you may have a bum sensor. The senosr is located middle of the firewall behind the I/M.
Old Jan 27, 2008 | 03:49 PM
Comp97GSR's Avatar
Default Re: (Comp97GSR)
Actually, I just checked. Code 90 is a leak at the fuel tank, more than likely the fuel cap. I currently have a defective fuel cap that needs replaced b/c it comes loose after a few miles. I suggest replacing yours too.
BTW, you will need to reset the ECU to clear the code.
Old Jan 27, 2008 | 07:02 PM
my fuel cap doesnt come loose though so wtf could it be?
Old Jan 27, 2008 | 07:32 PM
coolhandluke's Avatar
Comp's suggestion only cost $6.32 from Son's Acura:
http://www.sonsacuraparts.com/...dIrno=
Why not try it first?
Old Jan 28, 2008 | 12:03 PM
Default Re: (coolhandluke)
i kno theres 2 codes that make up the CEL code 90, ones for gas cap, ones for the EVAP system so ima bring it to my dads friend with a actual diagnostic tool. damn i wish that paper clip was more specific
Old Jan 28, 2008 | 12:56 PM
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importknight &raquo;</TD></TR><TR><TD CLASS="quote">i kno theres 2 codes that make up the CEL code 90, ones for gas cap, ones for the EVAP system so ima bring it to my dads friend with a actual diagnostic tool. damn i wish that paper clip was more specific</TD></TR></TABLE>
That is not true... here are the codes per the Helms.
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
Do whatever you feel is best.
Old Jan 28, 2008 | 01:38 PM
EKSedAndy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importknight &raquo;</TD></TR><TR><TD CLASS="quote">my fuel cap doesnt come loose though so wtf could it be?</TD></TR></TABLE>
The fuel system pressure is very touchy, and for a fuel cap to be faulty and giving a CEL, it doesn't have to sloppy and obviously loose. It can feel plenty tight, but just not be holding the proper pressure. They just plain wear out of time, and like someone else said, they're like $6. Get a new cap, make sure you turn it a good several clicks tight, and disconnect your battery to reset the ECU and see what happens. By far the easiest option to try first and definately the most common/likely.
Old Jan 29, 2008 | 12:11 PM
will do thx alot guys, jsut got me all in a fuss cause its my 2nd integra and ive only had it for a couple months and my last one gave me CEL problems all the time.
Old Jan 31, 2008 | 12:14 AM
DanielCarswell's Avatar
Just had this same CEL code. My problem was a hole in the EVAP canister as suggested already. The other suggestions on the error code print out were poor vaccuum seal on gas cap and purge solenoid valve leak. Check both of those out if you havent already.
Old Feb 2, 2008 | 05:38 PM
waat do u mean a whole, i kno where it is but what kinda whole like u had to replace the whole evap?
rotascircuit
Mar 24, 2008 05:22 PM
hockeyMike2489
Sep 27, 2006 08:44 PM
iwantturbo
May 17, 2006 09:32 PM
iheartDc2
Feb 4, 2006 08:26 AM
OnEsIcKLs
May 3, 2004 05:00 PM
