no spark fuel pump isnt working ef hatch dx obd1 jumper obd2 gsr... !!!PLEASE HELP!!!
Old Jan 26, 2008 | 07:39 PM
raceready1320's Avatar
Default no spark fuel pump isnt working ef hatch dx obd1 jumper obd2 gsr... !!!PLEASE HELP!!!
IM GETTIN SOOO IMPATIENT... IM USED TO THINGS WORKING RIGHT.. I CAN DO SWAPS USUALLU IN A DAY AND THIS ONE IS DONE BUT THE WIRING IS HOLDING ME BACK.. SOMEONE PLEASE HELP!!!
Old Jan 26, 2008 | 08:22 PM
black0hatch's Avatar
Default Re: no spark fuel pump isnt working ef hatch dx obd1 jumper obd2 gsr... !!!PLEASE HELP!!! (raceready
could be main relay, grounds, bad wireing.
Old Jan 30, 2008 | 12:59 AM
thanks captain obvious... i need someone thats more helpful!!! someone help!!
Old Jan 30, 2008 | 05:45 AM
HondaPartsHero's Avatar
Technical Hero
sounds like a bad or missing ground, especially the one on the thermostat housing will cause the ECU or the main relay to malfunction. what jumper did you use? how did you convert to MPFI?
Old Jan 30, 2008 | 10:07 AM
all those are there (all grounds) and i had a friend do the sub harness and i got a jumper from a friend and im not sure if this jumper is for dpfi... would it make a difference if the jumper is for a mpfi??
raceready1320
Jan 23, 2009 07:53 AM
raceready1320
Feb 8, 2008 04:18 AM
boosted 95 coupe
Jan 2, 2007 10:39 AM
SrT4u2nV
Dec 7, 2006 06:10 PM
crazykid9137
13
Aug 15, 2005 08:00 PM
