Car won't start, need quick help.
Old Jan 26, 2008 | 05:38 PM
sixfiveoh's Avatar
Sweet Title
Default Car won't start, need quick help.
94 LX Accord
Was cleaning my buddy's accord with him, he cleaned the engine bay, sprayed it down while the motor was running, no problems, he then drove it around the block a few times, parked it, shut it off to wash it. Tried to start it again and it wouldn't go. It's trying to turn over, but just keeps cranking, and we get alot of backfiring.
Tried to bump start it, didn't work, so we just got back from pushing it up the hill, I'm guessing it could be water in the plug valleys? Anyone have any idea?
Old Jan 26, 2008 | 05:50 PM
SkimN's Avatar
not much help but let everything dry, and next time spray some Simple Green on then spray it down with the hose and let it dry, don't drive it. g/l
Old Jan 26, 2008 | 07:41 PM
nickVtec's Avatar
something could have went wrong with the starter due to the water? and were there any problems with it not starting before it was washed or the problem just came up?
Old Jan 26, 2008 | 08:19 PM
sixfiveoh's Avatar
Sweet Title
Default Re: (nickVtec)
Nothing was wrong before the wash, but sometimes things like this are pure coincidence. He has compression, we tested the spark plugs for spark, and we put a couple gallons in the car just in case.
Now we're thinking maybe the fuel pump? Fuel pump regulator?
Old Jan 26, 2008 | 08:40 PM
SiREJ8's Avatar
Did you pull the cap off the distributor?
Have you checked for spark and fuel?
EDIT: Ok sorry didn't see you checked spark...
main relay?
Modified by SiREJ8 at 12:54 AM 1/27/2008
Old Jan 26, 2008 | 08:41 PM
sixfiveoh's Avatar
Sweet Title
Default Re: (SiREJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiREJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Did you pull the cap off the distributor?
Have you checked for spark and fuel?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixfiveoh &raquo;</TD></TR><TR><TD CLASS="quote">we tested the spark plugs for spark, and we put a couple gallons in the car just in case.</TD></TR></TABLE>
Haven't taken the cap off yet, what would we be looking for?
Old Jan 26, 2008 | 08:56 PM
SiREJ8's Avatar
Default Re: (sixfiveoh)
Haven't taken the cap off yet, what would we be looking for?</TD></TR></TABLE>
I'm gettin tired i missed that part were you checked spark, try tapping the main relay while trying to start or listen for the fuel pump to prime when you turn the key on...
Old Jan 26, 2008 | 10:19 PM
sixfiveoh's Avatar
Sweet Title
I'm gettin tired i missed that part were you checked spark, try tapping the main relay while trying to start or listen for the fuel pump to prime when you turn the key on...</TD></TR></TABLE>
Where is the main relay located in this car? We could hear the fuel pump priming, and we checked the fuel pressure valve on the fuel rail, it sprays fuel when we try to start the car.
Old Jan 27, 2008 | 05:30 AM
kjmoy's Avatar
Default Re: Car won't start, need quick help. (sixfiveoh)
You said you already checked your plugs, then the chances are your cap and rotor could have gotten wet and white stuff (calcium) built up with water seeping through. I would check that before anything else. Also check your oil and make sure no water get in it through the plugs.
Old Jan 27, 2008 | 07:05 AM
GhostAccord's Avatar
Default Re: Car won't start, need quick help. (kjmoy)
Take a hair dryer to all of the electrical connectors for the distributor, TPS and MAP sensors. there could be water in there causing a false signal to go to the ECU. Throwing the timing off.
Check to see if there are any DTC's stored on the ECU. You may have a code on there that could point you in the right direction. Jumper the SCS connector under the glove box, turn the ignition to the ACC position and make note of the long and short flashes. If the CEL stays solid then there are no stored codes.
Old Jan 27, 2008 | 08:25 AM
sixfiveoh's Avatar
Sweet Title
Default Re: Car won't start, need quick help. (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">Jumper the SCS connector under the glove box, turn the ignition to the ACC position and make note of the long and short flashes. If the CEL stays solid then there are no stored codes.</TD></TR></TABLE>
Is there any thread explaining in more detail on how to do this?
Old Jan 27, 2008 | 09:08 AM
shivic's Avatar
water in the dizzy. spring wd40 in the cap.
Old Jan 27, 2008 | 01:20 PM
sixfiveoh's Avatar
Sweet Title
Default Re: Car won't start, need quick help. (shivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shivic &raquo;</TD></TR><TR><TD CLASS="quote">water in the dizzy. spring wd40 in the cap.</TD></TR></TABLE>
Checked it last night, there's no water in there. We should spray wd40 in there anyway?
Old Jan 27, 2008 | 02:12 PM
There should be a blue connector under you glove box that looks like this.
Remove it from the mount that it is in under the glove box.
With the ignition off insert a paper clip clip or piece of wire bridging these two connectors.
With this connector shorted turn your ignition to the ACC/II position (engine not running) and watch the CEL for flashes. long flashes = 10s short flashes = 1s for example long...long...short...short...short...short would be code 24.
There may be more than one code stored on the ECU at one time. If there is more than one there will be a pause between them
Example long...long...long..short...short....(2-3 second pause).....long...long...short...short...short...s hort = codes 32 & 24. There can be more than two codes as well. I'm not 100% how many the ECU stores at one time but it will flash them all with pauses in between.
Old Jan 27, 2008 | 02:54 PM
sixfiveoh's Avatar
Sweet Title
Wow dude, thanks for the info. Where can I find a reference chart for all of the fault codes?
Old Jan 27, 2008 | 03:04 PM
sixfiveoh's Avatar
Sweet Title
We went out and tried that. There were two plugs plugged into that blue thing, one with 3 holes and one with 2, like the one you showed. We bridged the one with 2 holes, turned the key to II, and all we got was a solid CEL. Does this mean anything? Why won't it work?
Old Jan 27, 2008 | 03:17 PM
BLKFLSH's Avatar
It has no codes stored. If you crank the engine and pump the accelerator a couple of times, then remove a plug, is it wet with fuel? Do you smell the unburned gas inside the cylinder? If so, there is no spark to ignite the fuel. If the plug is dry, there is no fuel for the spark to ignite. This will at least narrow it down to either a spark or fuel related issue.
Old Jan 27, 2008 | 03:21 PM
sixfiveoh's Avatar
Sweet Title
We pulled the fuse for the ECU for a minute to let it reset, still nothing but a solid CEL when we bridge the connectors.
Old Jan 27, 2008 | 03:22 PM
sixfiveoh's Avatar
Sweet Title
Default Re: Car won't start, need quick help. (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">It has no codes stored.</TD></TR></TABLE>
Okay. So what could be wrong with the car, if it has spark, compression, and fuel and it's not throwing any codes?!
Old Jan 27, 2008 | 03:24 PM
BLKFLSH's Avatar
Read my edited post above, please.
Old Jan 27, 2008 | 03:26 PM
sixfiveoh's Avatar
Sweet Title
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">Read my edited post above, please.</TD></TR></TABLE>
We pulled a plug and held it against the block, and we had spark.
Old Jan 27, 2008 | 03:30 PM
BLKFLSH's Avatar
If you had just tried to start the engine, the plug should have been wet with gas. If the plug was not wet, I think your fuel injectors may not be working. Maybe try drying those wires, and checking the connectors.
Old Jan 27, 2008 | 03:34 PM
BLKFLSH's Avatar
You could have a main relay issue. Here's a very helpful link on main relay. Good luck. Read the other symptoms and causes down the page.
http://techauto.awardspace.com/
Old Jan 27, 2008 | 03:45 PM
sixfiveoh's Avatar
Sweet Title
After reading that, it sounds like it could be flooding?
Old Jan 27, 2008 | 03:55 PM
BLKFLSH's Avatar
Maybe the pressure regulator is not working right. Just guessing here. I would save that link if I were you. It may come in handy in the future. Good luck solving your problem.
