EP3 seats on my 93 civic hatch
Does anybody know how to make ep3 seats fit my eg, already tried changing the whole bottom metal piece(dont know the name) and it still didn't work
. Searched nothing came up, need help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el******hatch »</TD></TR><TR><TD CLASS="quote">Does anybody know how to make ep3 seats fit my eg, already tried changing the whole bottom metal piece(dont know the name) and it still didn't work
. Searched nothing came up, need help.</TD></TR></TABLE>
the bottom metal peice* is called a bracket... an the brackets u need i believe are the ones off an ITR or EM1... i saw thread somewhere n someone mentioned using one of those... dont like EP3 seats so dont kno much on this one but id just suggest searching harder..
. Searched nothing came up, need help.</TD></TR></TABLE>the bottom metal peice* is called a bracket... an the brackets u need i believe are the ones off an ITR or EM1... i saw thread somewhere n someone mentioned using one of those... dont like EP3 seats so dont kno much on this one but id just suggest searching harder..
Iam taking about the whole bottom metal piece thats under the cushion, I know what brackes are an how to change them, I've had Del Sol seats, but you cant do that with the ep seats need help making them sit right any one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">prepare for some 4x4 action.</TD></TR></TABLE>
lololololol
lololololol
i got the answer for that..
http://www.hondamarketplace.co...05056
look at the pics i have them on my EG i jsut took out the driver side.
well alls you have to do is...you know thos two little brackets the are on the front siede of the seat, cut the tack out with a sawzill, and just ratate them 180 dagrees, then you could eighter get them spot weld them or use 10mm bolt with nuts.
hope i helped if you have more Q's pm me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC »</TD></TR><TR><TD CLASS="quote">well alls you have to do is...you know thos two little brackets the are on the front siede of the seat, cut the tack out with a sawzill, and just ratate them 180 dagrees, then you could eighter get them spot weld them or use 10mm bolt with nuts.
hope i helped if you have more Q's pm me.</TD></TR></TABLE>
lol SAWZ-ALL, BECAUSE IT SAWS ALL..!!! sawzill, cuz its ill i could understand that, but just thought id fix the spelling for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 »</TD></TR><TR><TD CLASS="quote">Just picked up some for my EK and they had wleded brackets on the rear part of the seat rails. My passenger seat isn't lining up though
I love the seats though</TD></TR></TABLE>
i've had some in my EK for close to 8 months. i kept the EP rails and rear brackets, but i chopped off the EK and EP front brackets and put the EK front brackets on the EP rails. lowered the seat in of course to spot weld the EK brackets up front, yanked the seats, then finished the welding.
so if there's any confusion, i have the EP seats, rails, and rear brackets; with EK front brackets. hope this helps, works like a charm
I love the seats though</TD></TR></TABLE>i've had some in my EK for close to 8 months. i kept the EP rails and rear brackets, but i chopped off the EK and EP front brackets and put the EK front brackets on the EP rails. lowered the seat in of course to spot weld the EK brackets up front, yanked the seats, then finished the welding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC »</TD></TR><TR><TD CLASS="quote">
lol SAWZ-ALL, BECAUSE IT SAWS ALL..!!! sawzill, cuz its ill i could understand that, but just thought id fix the spelling for you </TD></TR></TABLE>
haha cool. i didnt' spell check.
Modified by Dead CIVIC at 6:41 PM 1/29/2008
T"u"Rtle
Apr 11, 2006 12:45 PM
alispoon
13
Mar 9, 2006 01:30 PM
egsnatchback
Feb 13, 2006 07:06 PM
