Anyone care to host pics of my piston? Not pretty!!
Old Jul 2, 2002 | 04:33 AM
No-Gi's Avatar
Default Anyone care to host pics of my piston? Not pretty!!
IM me at EK12psi or PM me.
Old Jul 2, 2002 | 04:44 AM
sackdz's Avatar
Default Re: Anyone care to host pics of my piston? Not pretty!! (B16aEK)
http://www.we-todd-did-racing.com
Old Jul 2, 2002 | 05:22 AM
No-Gi's Avatar
Default Re: Anyone care to host pics of my piston? Not pretty!! (sackdz)
I signed up, uploaded the pics but I cannot seem to get them here.
[Modified by B16aEK, 2:23 PM 7/2/2002]
Old Jul 2, 2002 | 05:24 AM
sackdz's Avatar
You linked it wrong... click on the picture then copy the URL listed above it, not the URL in the address bar....
Old Jul 2, 2002 | 05:26 AM
Dr Pooface's Avatar
No workee
You have to up it to we-todd, and then click on your pic there and copy the shortcut. Then you insert the shortcut between [IMG.]and [/IMG.] with no periods.
Old Jul 2, 2002 | 05:29 AM
No-Gi's Avatar
I REALLY SUCK AT THIS !!!
[Modified by B16aEK, 2:35 PM 7/2/2002]
[Modified by B16aEK, 2:36 PM 7/2/2002]
[Modified by B16aEK, 3:17 PM 7/2/2002]
Old Jul 2, 2002 | 05:34 AM
Dr Pooface's Avatar
SuperTwinz's Avatar
explain what happened...
Old Jul 2, 2002 | 05:38 AM
No-Gi's Avatar
Default Re: Anyone care to host pics of my piston? Not pretty!! (SuperTwinz)
Bad cam install by a local shop.
I was using Skunks stg II. Those are Wiseco piston
The cam gear was a bit off, maybe a couple of degrees.
Old Jul 2, 2002 | 06:02 AM
Turtle's Avatar
Did you get your money back? How much did you pay for the install + parts?
Old Jul 2, 2002 | 06:03 AM
BDiddy's Avatar
Default Re: Anyone care to host pics of my piston? Not pretty!! (401-2001)
looks good to me... Whats the problem?
Old Jul 2, 2002 | 06:12 AM
No-Gi's Avatar
This shop has a tendency not to accept mistakes. I did not pursue them at all. The head has damaged from the valve smashing the combustion chamber. I will be replacing the piston pretty soon as well as buying another head.
[Modified by B16aEK, 3:18 PM 7/2/2002]
Old Jul 2, 2002 | 06:46 AM
Shaotai's Avatar
Why don't you tell us the shop name, so we can avoid bad installs there....
Shops who don't take responsibility
Old Jul 2, 2002 | 07:19 AM
Darkteg's Avatar
New User
Default Re: Anyone care to host pics of my piston? Not pretty!! (Shaotai)
looks bad.. did it damaged the combustion chamber also?
Old Jul 2, 2002 | 07:28 AM
NAB20C5's Avatar
Default Re: Anyone care to host pics of my piston? Not pretty!! (Darkteg)
Aww dude, nothing a lil JB weld won't cure...
But sorry to hear about your bum experience...hope you get the motor put back together the right way so you get your car running again...best wishes
Old Jul 2, 2002 | 07:34 AM
Pinhead's Avatar
New User
Default Re: Anyone care to host pics of my piston? Not pretty!! (NAB20C5)
Damn Carlos, that shop is usually known for good work....and if it was indeed their fault they should take responsibility for it. anyhow, good luck with the new project
Old Jul 2, 2002 | 07:37 AM
sackdz's Avatar
If it is indeed their fault, then that's ridiculous, or your made of money, one of the two. They fuckup, they pay. Proving it might be another matter but you could at least try. What is the story anyway? "The cam gear was off a couple teeth" What they didn't run the motor after they built it or what? The pulley slipped?
Old Jul 2, 2002 | 08:42 AM
underrated99si's Avatar
Damn that sucks major ***** sorry to hear and see that pic but I would raise hell with that shop and make them cover some of the damage or buy you new valves and pistons or something
Old Jul 2, 2002 | 09:01 AM
RTW DC2R's Avatar
Default Re: Anyone care to host pics of my piston? Not pretty!! (underrated99si)
OUCH. Ive seen something similar to that, only nitrous was used to create the damage, not screwed up timing. That shop should pay because you entrusted them to do the work and do it right. Since they didnt do it right, they are at fault. Seems to me it would be their responsibility to set the timing correctly, especially after installing cam/pistons/etc. i dont care what shop it is, its your money and you should definitely raise hell
Old Jul 2, 2002 | 09:37 AM
Tommy_Gunns's Avatar
Default Re: Anyone care to host pics of my piston? Not pretty!! (Ddub)
At first I thought that was a coin beside the piston. Then I looked a little closer and damn that's a valve bottom with no stem.
Old Jul 2, 2002 | 10:03 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
WOw that looks like what happend to my motor. But my problem was the timing belt, not the work done. And my head got tore up as well, but not only have I replaced the head, I am havng to replace the block as well.
And this engine failure happen'd when I was cruising @ about 65-70
ghloto
Aug 29, 2002 07:45 PM
ProstockH22crx
Jun 21, 2002 09:22 AM
neof69
Feb 11, 2002 02:26 PM
