Hornet alarm only works now when ignition is on. wtf
Old Jan 26, 2008 | 12:19 PM
hb_guy's Avatar
Default Hornet alarm only works now when ignition is on. wtf
i recently disconnected my power and ignition wire to do some work on my car and left the alarm disconnected for a few weeks. Today i reconnected the two wires and my alarm only works when the car is on. obviously i need it to work when the car is off(duh). but i have no clue why it is not working now.
I reset the alarm, took off the neg terminal on the battery and still nothing. Any clues? It is the basic 2 button Hornet alarm. It is comparable to the Viper 300.
Thanks
Old Jan 26, 2008 | 06:03 PM
95jdmej2's Avatar
Default Re: Hornet alarm only works now when ignition is on. wtf (hb_guy)
Man it sounds like one of those to wires you disconnected is hooked to something keyed. If you hook it to something that stays hot all of the time (battery) then everything should work fine. Unless i have misunderstood you, that should be it. What is the model number of the hornet.
Old Jan 27, 2008 | 07:04 AM
suspendedHatch's Avatar
What do you mean you disconnected your "ignition wire"? What wire is that?
Sounds like you reversed your alarm's power and ignition inputs or something crazy.
Old Jan 27, 2008 | 10:24 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean you disconnected your "ignition wire"? What wire is that?
Sounds like you reversed your alarm's power and ignition inputs or something crazy.</TD></TR></TABLE> Ditto that.
If the alarm worked before you disconnected the alarms ign. and constant power inputs and now it works only when key is on, then you have switched the inputs. 94
Old Jan 27, 2008 | 01:23 PM
hb_guy's Avatar
Default Re: Hornet alarm only works now when ignition is on. wtf (fcm)
switched the red/ylw wires. thanks guys.
SCR ZC-T
Audio / Security / Video
Sep 30, 2013 04:59 PM
unknown_user1
Dec 14, 2012 10:54 PM
infinitypro12
Jun 15, 2009 06:59 PM
mike5809
Apr 13, 2007 08:34 PM
Jdmglenn
Oct 20, 2006 05:38 PM
