Tucked brake lines, How to bleed a dry system?
I'd use a little modified version of both. Crack all the bleeders at the calipers/drums and pour your fluid. You’re consistently going to have to pour fluid as it pushes the air out and fills the lines. Making sure that the reservoir always has fluid or your just going to let air back into the system. Once it does I would close them up and bleed them like you would normally.
Bench bleeding MC's is a universal job. No difference between imports and domestics.
Google "How to bench bleed a master cylinder"
or read this write up.
http://www.superchevy.com/tech....html
hybrid90
Suspension & Brakes
Oct 14, 2008 10:07 AM
weakGOODJunKieS.com
Jun 2, 2003 04:30 PM
