actuating the EGR while removed?
Old Jan 26, 2008 | 07:47 AM
budomove's Avatar
Default actuating the EGR while removed?
Nevermind, I did it!
Thanks anyway
car is a 2000 honda insight
I need to actuate the valve while it is removed and soaks, to better clean/lube the valve.
I need to connect pos 12v to pin 4, and neg 12v to pin 6.
I tried buying small gauge jumper wires, but autozone didnt have them.
Can I just use jumper cables, and stick a paper clip on the neg and pos to fit in the connector pins on the egr?
Are jumper cables too thick, and they would fry the egr, or am i dumb, and its the same current either way?
Thanks Everybody!
Modified by budomove at 11:00 AM 1/26/2008
supercharged d
Aug 6, 2009 03:59 PM
civic-si-2000
Sep 20, 2003 09:11 AM
fe519
Mar 22, 2003 08:53 AM
