vtec not working =(
Old Jan 26, 2008 | 07:26 AM
97civic94gsxr's Avatar
Default vtec not working =(
I have a 97 civic with a gsr swap and the vtec is not working it has a computer thats labeled B16 and the vtec solenoid was replace and i was trying to figure out what else it would be any help would be appreciated.
Old Jan 26, 2008 | 08:19 AM
97Ej6mike's Avatar
GSR motors require the GSR ecu in order to properly operate their secondary butterflys, which active around 3200ish i believe. Without it, the motor will not perform correctly.
Old Jan 26, 2008 | 08:35 AM
994door's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">GSR motors require the GSR ecu in order to properly operate their secondary butterflys, which active around 3200ish i believe. Without it, the motor will not perform correctly.</TD></TR></TABLE>
I dont think that would have any thing to do with vtec not engaging. The IAB's open at 6000 vtec is at 4500. The only difference would be no IAB and vtec engaging at a different rmp. First for vtec you have to be moving, car warmed up, and throttle position. Probably something as well. Hook up a 12v light inline with the wire to the vtec solenoid. All it is, is a 12v switch. If you still have problems pick up a repair manual. Theres alot about diagnosing vtec problems.
Old Jan 26, 2008 | 08:54 PM
97Ej6mike's Avatar
Default Re: (994door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door &raquo;</TD></TR><TR><TD CLASS="quote">
I dont think that would have any thing to do with vtec not engaging. The IAB's open at 6000 vtec is at 4500. The only difference would be no IAB and vtec engaging at a different rmp. First for vtec you have to be moving, car warmed up, and throttle position. Probably something as well. Hook up a 12v light inline with the wire to the vtec solenoid. All it is, is a 12v switch. If you still have problems pick up a repair manual. Theres alot about diagnosing vtec problems.</TD></TR></TABLE>
Other way around, IABs at about 3500ish or so. Wihtout them, it feel likes crap when their supposed to be open and are not.
Old Jan 26, 2008 | 08:55 PM
speedooo's Avatar
the the ecu isnt looking for iabs, that doesnt mater
Old Jan 27, 2008 | 07:38 AM
Bre_Carchief's Avatar
Default Re: vtec not working =( (97civic94gsxr)
is your civic a vtec car or did u wire up vtec?
Old Jan 27, 2008 | 07:50 AM
994door's Avatar
Other way around, IABs at about 3500ish or so. Wihtout them, it feel likes crap when their supposed to be open and are not. </TD></TR></TABLE>
I've got a gsr in my civic. IAB open and 6000. Vtec at 4500. But look at the ecu again for a P number. It has a P then two numbers after that. That will tell you what ecu you have.
Old Jan 27, 2008 | 02:15 PM
rdemotta's Avatar
DID YOU CHECK THE OIL LEVEL. IF ITS LOW VTEC WILL NOT WORK
Old Jan 27, 2008 | 02:16 PM
rdemotta's Avatar
If the oil level is low vtec will not work
Old Jan 27, 2008 | 02:42 PM
dragonfly2k3's Avatar
Default Re: vtec not working =( (rdemotta)
Check your wiring, make sure nothing is cut/shorting to ground. Does it throw and CELs? Check you're oil level, get the car up to full operation temperature, with full oil, and no CEL's and smack on it in second full throttle until redline. Does it open? Does your speedo work? Is your tps good?
Old Jan 27, 2008 | 03:10 PM
pdotjones's Avatar
Default Re: vtec not working =( (dragonfly2k3)
how do you know its not working?
Old Jan 27, 2008 | 03:57 PM
jdmej814's Avatar
Default Re: vtec not working =( (pdotjones)
it happened to me..but the funny thing was i had lowwwwww oil!! like really low!! that was a my bad too! and my vtec stoped functioning correctly..tryin doin an oilchange
Old Jan 27, 2008 | 04:05 PM
No i keep the oil full and the only thing that i know of that needs replaced is the IACV. Its an hx model so it was wired for SOHC vtec originally but it has an OBD2 to OBD1 jumper on it and it was wired by a performance shop. And i know its not working because i've had DOHC vtec in MY B16 crx so i know what DOHC vtec sounds/feels like
VTECth1s
Aug 22, 2006 09:53 AM
finest_GSR
Apr 6, 2006 09:09 PM
J's GS-R
Feb 21, 2006 09:13 PM
shyboi4u
Oct 7, 2005 11:54 PM
matt87
Sep 10, 2005 07:27 AM
