Rear hub/bearing from Civic Si/Integra GSR
Old Jul 2, 2002 | 02:02 AM
ckkl's Avatar
Default Rear hub/bearing from Civic Si/Integra GSR
Hi all,
Just wondering: I know the disc brakes on the 92-95 Civic Si and the Integra GSR are the same size -- my question is: do they also share the same hub/bearing assembly?
I need to source a rear hub since my rear wheel bearing on my EG6 is making noise.
Does anyone have experience with this?
Thanks...
Old Jul 2, 2002 | 11:13 PM
ckkl's Avatar
Default Re: Rear hub/bearing from Civic Si/Integra GSR (ckkl)
TTT
Come on guys?
I know many of you have experience with the hub assembly on Integras and Civics (from doing brake conversions etc.)
Are the hubs from Integras and Civics (Si at least?) the same? Honda won't help me since my car is JDM and they don't deal with it. Some help please? I just need to fix my screwy bearing; what do I look for at the scrap yard?
Old Jul 2, 2002 | 11:17 PM
tonyxcom's Avatar
"should" be the same.
Old Jul 2, 2002 | 11:36 PM
migs's Avatar
Default Re: Rear hub/bearing from Civic Si/Integra GSR (tonyxcom)
If you are talking about the Hub, meaning the peice that holds the studs in place. Spindle or Hub? They are the same. Good luck.
Old Jul 3, 2002 | 12:41 AM
ckkl's Avatar
Default Re: Rear hub/bearing from Civic Si/Integra GSR (MiGs)
Ok excellent. I'm 99% sure the SiR brake package is identical to the Civic Si and Integras (although rear LCAs are not shared strangely).
When it comes to terminology about the hub, I'm a bit confused.
Spindle refers to which part? The part that the wheel touches when mounted right?
And the hub is within/behind the spindle? and within the hub is the bearing?
Thanks for the help
Old Jul 3, 2002 | 03:07 AM
ckkl's Avatar
Ok I edited this image that someone posted.
Can someone who knows please tell me:
What on it is the spindle or the hub (where the bearing is housed)?
I just want to make sure I'm calling everything the right name.
Old Jul 3, 2002 | 03:17 AM
BakedCookies's Avatar
both or your arrows are pointing to the rotor the hub assembly is behind the rotor, it is held onto the trailing arm with one large nut, remove the caliper and the caliper bracket, remove the 2 philips screws that hold the rotor on, un crimp the large bolt, remove... and the hub will slip off...
Old Jul 3, 2002 | 04:13 AM
eg6ajk's Avatar
yes the bearing and hubs seem to be identical on all 4x100mm Civic/Integra/CRX cars...
the one thats different is ITR (type R) it has a shaft which is about 5mm longer then all the others
Old Jul 3, 2002 | 09:30 PM
ckkl's Avatar
Default Re: Rear hub/bearing from Civic Si/Integra GSR (eg6ajk)
I was originally thinking the same thing; however my workshop (I'd rather not go through them to save cash) used to run an EG5 Civic Si (in Australia, that's the USDM Civic Si but with a ZC engine -- there's also the Civic VTi which is SOHC VTEC, same as the USDM Civic Si).
When ordering the new bearing from the dealer, they said there are 3 different bearing types so he had to show his ruined one so they could find a suitable replacement.
Anyway, thanks for the help fellas. You've cleared things up for me.
EDIT: ****, one more thing...
My workshop told me I can't change the bearing from a wrecked car since once you extract the used one, it all "falls apart" and you can't repack it. I can only replace it with a new one from Honda. HOWEVER, just want to confirm: if I want to get a used bearing, I can just replace the entire hub which contains the bearing right? (And can you guys confirm for me what the workshop said...?)
Thanks again...
[Modified by ckkl, 4:34 PM 7/4/2002]
Old Jul 4, 2002 | 04:08 AM
VWkila's Avatar
Are there Autozone or Pepboys in Austrailia?
Rebuilt ones that are sold in these autopart stores are great. Keep your old parts for a core charge.
5th gen Civic and 95+ Integras have interchangeable suspension parts. Even the ITR have the same mounting points as Civics.
I don't know about not being able to pack the used ones. I've talked with a suspension engineer at work, he said a ball bearing on a typical car should last a lifetime of a vehicle these days.
Old Jul 4, 2002 | 06:42 AM
migs's Avatar
Default Re: Rear hub/bearing from Civic Si/Integra GSR (VWkila)
Remove the brake locator screws. Behind the disc is a hub which has 4studs pressed onto it. The hub is pressed onto the wheel bearing.
Note: You cannot see the actual hub and bearing from that picture.
Old Jul 4, 2002 | 06:44 AM
ckkl's Avatar
What's Autozone or Pepboys? There's not much support for Hondas in Australia outside of Honda themselves.
My car's worn bearing may be attributed to the previous owner who ran the car on compressed springs for looks.
Old Jul 4, 2002 | 06:49 AM
migs's Avatar
Autozone and Pepboys are automotive shops that provide NON-OEM replacements parts and automotive care for US. Its a franchise here int the states.
Old Jul 5, 2002 | 06:55 AM
ckkl's Avatar
Turns out my friend has a rear hub from a EG..... (woohoo)
It's from a car with drum brakes, but I don't think that matters since the hub is independent of the brakes correct?
(Just need some confirmation that I can use this hub on my disc-equipped car)
Old Jul 5, 2002 | 10:22 PM
dchu's Avatar
I don't know if it matters but I'm using my stock '99 drum hubs on my rear discs. The disc conversion I bought had hubs that were rusted to hell so I decided to use my stock ones. Only difference is that drum hubs don't have the threaded holes for the rotor retaining screws.
TeeO
Oct 17, 2012 08:29 AM
xaine
Apr 30, 2009 07:46 PM
:Andrew
Nov 3, 2006 08:45 AM
XkjeldorX
Mar 28, 2006 03:39 PM
