tac/o2 wire
Old Jan 26, 2008 | 04:20 AM
citystreetsbimmer's Avatar
Default tac/o2 wire
on my 92 hatch 1.5 what pin or color wire is the o2 signle going to the ecu? i wanna put an air fuel gauge but rather tap to the ecu. or anyone know wich color to the o2 sensor if i have to go that route. also how about the tachometer wire behind the dash the goes to the cluster?
Old Jan 27, 2008 | 01:06 AM
Default Re: tac/o2 wire (citystreetsbimmer)
bump
Old Jan 27, 2008 | 04:25 AM
JSPECSIR's Avatar
white, pin 14 at ecu(cant remember which plug) or white at o2 unless its something other than 4 wire o2.
and tach is blue at tach test connector on drivers side strut tower. in a 2 pin blug by itsself with a rubber cap on it. i dont know about at the cluster. maybe some one else does.
Old Jan 27, 2008 | 05:38 AM
HondaPartsHero's Avatar
Technical Hero
http://technet.ff-squad.com/wiring.obd1.htm
Old Jan 27, 2008 | 11:02 AM
Default Re: tac/o2 wire (HondaPartsHero)
thank you for the info fellas
Old Jan 27, 2008 | 11:06 AM
Slopoke's Avatar
Dont waste your time running an a/f gauge off of a stock narrow band o2 sensor.
It wont be accurate.
Old Jan 27, 2008 | 05:54 PM
Default Re: (Slopoke)
i hav ehad an autometer air/fuel gauge and volt gauge sitting in a box for ayear now i might aswell do somthing with it.
Crab Man
May 18, 2007 06:43 PM
flipsyde
Feb 26, 2006 08:13 PM
PearlWhiteAccord
Dec 31, 2005 01:40 PM
DLB1994
Dec 13, 2003 07:25 PM
X2BOARD
Jul 14, 2003 09:21 PM
