Can I use my old MAP sensor for my B20 VTEC swap?
It looks the same as a DA Integra, but is my firewall mounted MAP sensor from my DPFI hatchback suitable for a swap, or do I need to change it?
I kinda dont think so... I am thinkin like the TPS DPFI wont work with MPFI so I am thinkin that the DPFI map may not work for MPFI ?
It will work the same, you can either use the firewall mounted map or the newer style one on the throttle body you just have to extend the wires. I would just keep the one on the firewall
david22ky
19
Aug 21, 2007 08:11 PM
ENJOI
11
Aug 23, 2006 10:39 AM
