sohc q/a d16z6
Old Jul 2, 2002 | 12:31 AM
madhatch's Avatar
Default sohc q/a d16z6
d16z6 motor, I am installing it into a 98 hatch I am looking for info on a build for it, the motor was free and runs 127000 miles. I want to run a 75 shot on the track looking for someone who has some SOHC experiance. The motor came from a 95 del sol, as did the tranny. I know it isnt a B16,B18 but it has some potential tryin to keep from going to wild.
Old Jul 2, 2002 | 12:37 AM
DOMKID's Avatar
Default Re: sohc q/a d16z6 (madhatch)
Mista bone is running low 13s on a pretty stock D16z6(not 100% sure ) 92 hatchback with a 75 shot zex. Ill be careful with an engine with such high mileage if i were you , you might need to upgrade some stuff.If you want more info on the D engine you should check out. http://pub34.ezboard.com/bhondadseries.
Old Jul 2, 2002 | 04:12 AM
Mista Bone's Avatar
D Tranny Guru
75 shot is pushin the envelope. You WILL need the biggest Walbro Honda fuel pump, FPR, and tuning. Start at 50 shot and work up.
Old Jul 10, 2002 | 01:05 AM
madhatch's Avatar
Default Re: sohc q/a d16z6 (Mista Bone)
Thanks MistaBone, and also thanks for the other forum the knowledge is very pleasing. I will post my build as it goes along and when I put it to the test.
E9CiViC1F
Feb 15, 2009 12:16 AM
slow_EJone
Oct 19, 2006 07:24 PM
The Up Garage
Oct 5, 2006 09:40 AM
95 vtec
Jul 8, 2006 07:49 AM
JdmVetteEater
17
Apr 28, 2003 02:46 PM
