'95 Accord power window question
Hi,
Got a question about 95 accord EX sedan, can you swap the motor of the front passenger side window to the rear passenger side window? The motor in the front is sluggish and I want to fix it or is there other options to fix the sluggishness.
The window is not tight nor the rubber its just it takes too long to go up and down, and I have a fresh new battery installed.
Thanks
Thanks
answer is no, due to the height of the motor/regulators and how much they allow the window to go up and down. Front windows go down a few inches more than the rear windows can.
now if I were to replace the regulator and cannot find the regulator do I have to get that specific one or model for the car or any other accord regulator is ok.
btw can you get this at your LAS store?
bop Sounds like we have similar problems. I have 97 honda accord. Window goes down,but wont come back up. Passenger window same way except it does come back up slooowwwlly so far. Figure it will do the same thing as the drivers door eventually. I took off door panel & was able to get window up by using battery charge for power. Using first plug coming off window motor to put power n to get motor back to up position.Obviously if motor is out,u will not have same results. HOPE THIS HELPS. Still looking for answer to my prob. Thinking it is switch or relay"module"..NOT SURE
THANKS AGAIN
THANKS AGAIN
corkss
Nov 30, 2008 06:46 PM
xkrakenx
Apr 24, 2008 06:12 PM
