H22 TURBO under powered!!!
Old Jan 25, 2008 | 11:08 AM
Weez's Avatar
Default H22 TURBO under powered!!!
Help... I have a H22 with a turbo running 8.5LBS of boost. 2.5" exhaust msd ignition with blaster coil. spark plugs wires. RC550CC injectors. hondata s300 in a p28 ecu. plus more but it is only puting down 230hp to the wheels. any ideas
Old Jan 25, 2008 | 01:24 PM
gibsanez's Avatar
Default Re: H22 TURBO under powered!!! (Weez)
We need a dyno chart, A/F's, and more information about your build before we can even begin to help.
Old Jan 25, 2008 | 01:25 PM
CivicSpoon's Avatar
got a little more info? what turbo? is it a kit? if so, what kit? stock engine?
Old Jan 25, 2008 | 03:01 PM
h22 civic's Avatar
Default Re: H22 TURBO under powered!!! (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon &raquo;</TD></TR><TR><TD CLASS="quote">got a little more info? what turbo? is it a kit? if so, what kit? stock engine?</TD></TR></TABLE>
Old Jan 25, 2008 | 03:33 PM
Weez's Avatar
Default Re: H22 TURBO under powered!!! (h22 civic)
its pieced togather t3t4 turbo with thrustbaring. large frontmount intercooler
Old Jan 25, 2008 | 03:38 PM
Weez's Avatar
and its a stock motor it should be puting down 280-300 to the wheels but 230 when i did the first dyno it put down 252 i intigrated the wastgate into the down pipe and then it put down 200 i lost 52hp. now i put on a highflow cat and cut off most of my exhaust from 2 1/4 to 2.5" exhaust.
Old Jan 25, 2008 | 06:11 PM
boostedh22lude1's Avatar
boost leak? how the car run? help us help u
Old Jan 29, 2008 | 12:53 PM
Weez's Avatar
Default Re: H22 TURBO under powered!!! (boostedh22lude1)
boost is strong and steady im thinking that i just need to make my exhaust bigger 2.5 all the way back
Old Jan 29, 2008 | 04:05 PM
doood's Avatar
been there done that
post the dyno graph
Old Jan 31, 2008 | 09:48 AM
CivicSpoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weez &raquo;</TD></TR><TR><TD CLASS="quote">boost is strong and steady im thinking that i just need to make my exhaust bigger 2.5 all the way back</TD></TR></TABLE>
Do you mean bigger than 2.5 all the way back, or are you saying that the entire exhaust isn't already 2.5 all the way back?
JDm.H22
Sep 6, 2007 07:12 AM
kornerk12
Aug 27, 2006 12:07 PM
h22dx
Dec 4, 2003 03:44 PM
mikeaagesen
Apr 28, 2003 07:37 AM
