Need help with broken ignition column
Guys my stolen CRX was recovered and now i have to fix the column. The cylinder key housing must be replaced.
I wanted to know if this housing is what makes the steering wheel lock when the key is removed??
I need this parts with brackets and all....where can i get it??
Modified by alscrx at 1:59 PM 1/25/2008
Modified by alscrx at 2:05 PM 1/25/2008
Modified by alscrx at 5:16 PM 1/25/2008
From: I told you to wait in the truck in Texas, United States
The oval piece that looks like a dead-bolt slide is what
locks the steering...
It extends when the key is removed and meshes
with the adjacent hole in the steering tube.
You can get that replacement part from a local junk yard out of a CRX/Hatch. You will have to swap around your key locks into the new set though which is kinda PITA.
if you get it from a dealership or parts store you gota buy the whole thing with the lock and key. its expensive though thats why your better going to the junk yard like the other guy said.
Why does majestic honda list the same part with 2 different part numbers for #3 and #4???
What the hell are the difference's??
84832 003 COVER, HOLDER
84833 003 COVER, HOLDER
49701 004 BOLT, BREAK HEAD
20708 004 BOLT, BREAK HEAD
Modified by alscrx at 5:23 PM 1/25/2008
Modified by alscrx at 5:24 PM 1/25/2008
Kei-EF8
Dec 18, 2003 09:05 PM
Honda318dx
19
Aug 26, 2001 01:15 PM
