o2 wire
Old Jan 25, 2008 | 07:34 AM
92nahatch's Avatar
Default o2 wire
read my next post
Modified by 92nahatch at 7:13 PM 1/26/2008
Modified by 92nahatch at 7:15 PM 1/26/2008
Old Jan 25, 2008 | 08:15 AM
tibss's Avatar
Default Re: o2 wire (92nahatch)
Luckly I have the paper work from rywire on the obd0 to obd1 converstion instruction. Here is exactly what it says.
1. Connect the BROWN wire to one of the BLACK wires on the 4 wire 02 sensor
(O2 Heater Control)
2. Connect the PURPLE wire to the GREEN wire on the 4 wire O2 sensor
(O2 Ground)
3. Connect the YELLOW wire to one of the BLACK wires on the 4 wire O2 sensor
(O2 12v Switch)
4. Connect the GREY wire to the WHITE wire on the 4 wire O2 sensor
(O2 Signal)
Becasue of the number of diffrent O2 wire colors, these may vary, and you may need to try moving these around.
I hope this helps you out.
Old Jan 25, 2008 | 10:36 AM
HondaPartsHero's Avatar
Technical Hero
http://hondaswap.com/reference...28667/
should be C16 a white wire
Old Jan 26, 2008 | 06:10 PM
92nahatch's Avatar
Default Re: o2 wire (HondaPartsHero)
i have an obdo crx with an obd1 ls converted to obdo in it. aka obd0 dizy and altenator.
i have a dc sports header on it and i got an o2 from a buddy and it has one wire on it.
Shouldnt the harness have a single wire than is like wraped buy it self so it doesnt burn on the exahust that hangs down for an o2 bung on the test pipe?
if so what pin would it be on the 3 plugs that are on the top left of the strut tower if the harness is obd0
Old Jan 27, 2008 | 08:42 AM
tibss's Avatar
From what I have understood if you have a obd1 ecu it is required to to put in a 4 wire o2 sensor. I am running into the same problem.
Old Jan 27, 2008 | 05:35 PM
92nahatch's Avatar
Default Re: o2 wire (tibss)
i need obdo thanks for adding to the confusion
Old Jan 28, 2008 | 02:58 AM
tibss's Avatar
Sorry I must have misread your post
Old Jan 28, 2008 | 10:04 AM
92nahatch's Avatar
bump
bmxtrev
Jun 28, 2012 09:17 PM
slammedz6ef
Feb 15, 2008 07:46 AM
hksdrager
May 11, 2007 07:55 PM
redflaredb1690
May 12, 2006 01:56 AM
