6month old swap. Randomly doesnt start
Old Jan 24, 2008 | 06:51 PM
Nashville's Avatar
* B A N N E D *
Default 6month old swap. Randomly doesnt start
Specs
1992 honda civic VX
b18c1
mild build.
p28 crome basemapped.
problem:
regardless of the weather i will go out to my car and go start my car, it cranks and everything, but wont fire. ill wait like 10 min. try again. it starts!! it doesnt do it at any specefic time. it will do it when the car is warmed up and it will do it when its cold. i can kick start it down a hill. (only done that once) i have a new distributor and it doesnt smell like its flooding. the motor was rebuiltt with OEM new everything. im thinking its my main relay. but any imput is welcome.
Old Jan 24, 2008 | 07:23 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: 6month old swap. Randomly doesnt start (Nashville)
could be a variety of things. spark plug wires, spark plugs, low compression, distributor cap, distributor rotor. how old are you wires?
Old Jan 24, 2008 | 07:26 PM
Nashville's Avatar
* B A N N E D *
Default Re: 6month old swap. Randomly doesnt start (2fast4u831)
everything is new, wires.. Maybe a yr old. Compression is 280 across the board
Old Jan 24, 2008 | 07:29 PM
2fast4u831's Avatar
I'm really 2slow
what kind of wires are you using?
Old Jan 24, 2008 | 07:31 PM
Nashville's Avatar
* B A N N E D *
ngk. They're blue
Old Jan 24, 2008 | 07:47 PM
2fast4u831's Avatar
I'm really 2slow
is the rotor clean? stock coil?
Old Jan 24, 2008 | 07:54 PM
Nashville's Avatar
* B A N N E D *
brand new dizzy
Old Jan 24, 2008 | 07:55 PM
2fast4u831's Avatar
I'm really 2slow
how's the timing look? did you make sure everything is aligned. cams and crank pulley?
Old Jan 24, 2008 | 08:06 PM
Nashville's Avatar
* B A N N E D *
I could check that. But if that was the prob wouldn't it do it everytime? And why would I have to wait ten min to start again
Old Jan 24, 2008 | 08:15 PM
2fast4u831's Avatar
I'm really 2slow
don't know but it is always good to check everything.
Old Jan 24, 2008 | 08:42 PM
Nashville's Avatar
* B A N N E D *
true
Old Jan 24, 2008 | 08:44 PM
2fast4u831's Avatar
I'm really 2slow
do you hear your fuel pump everytime the key is on?
Old Jan 24, 2008 | 09:27 PM
Nashville's Avatar
* B A N N E D *
yep, everytime. just installed a walbro 190..
Old Jan 25, 2008 | 04:11 AM
Nashville's Avatar
* B A N N E D *
bump
Old Jan 25, 2008 | 07:21 AM
2fast4u831's Avatar
I'm really 2slow
engine ground are ok?
Old Jan 25, 2008 | 12:06 PM
atlplayer4life90's Avatar
just cause the pump turns on does not mean its working right make sure that you have fuel at the rail when you turn the key to the on position it happened to me once.
Old Jan 25, 2008 | 10:02 PM
sauceja's Avatar
Default Re: 6month old swap. Randomly doesnt start (atlplayer4life90)
clogged fuel filter or filter by your fuel pump? Bad gas? dirty gas?
Pull your plugs are they black? smell like gas or burnt smell? Look like they have been leaned out?
Do you have a wideband to see what A/F ratio is at?
Just trying to throw some ideas out there. Get a helms and test the coil and ICM. Just because its new doesn't mean it isn't bad.
When you did a compression test did you unplug the distributor or leave it plugged in.
If you left it plugged in and just removed the wires that could destroy your dizzy because of the built up charge not having anywhere to go and fries your coil.
Old Jan 27, 2008 | 10:28 PM
JDMGTI's Avatar
I had the same problem, so I asked a tech at a local honda dealership, he told me to replace the pigtail from the keyswitch to the fusebox.
sometimes, the solder connections on the back of the ignition switch go bad and cause a hairline fracture on the circuit board, when its cold, it doesnt start, when it warms up just a little (key turning, friction), it will start.
the pigtail is about 30 bucks at the dealership. give it a shot. worked for my accord and civic.
its funny, everyone will swap out the motor and all that stuff, no one even looks at the ignition switch, which turns several times a day, for years.
Old Jan 28, 2008 | 08:31 PM
jdmboyef9's Avatar
Ok try this. Next time your car won't start, turn the key on so that the check engine light comes on briefly (light buzzing noise) and then turns off. When the light turns off you should here a click as the relay turns off. If you don't hear a buzz followed by a click, then your relay is bad. It is very common with older Honda's and is a very easy fix.
Old Jan 30, 2008 | 06:16 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (jdmboyef9)
http://techauto.tripod.com/mainrelaydefine.htm
I'd at least pull the main relay and check the board on it
todahead
Jul 23, 2012 09:35 AM
mikedaruto
Jun 26, 2012 12:14 PM
gizmo jdm
Nov 14, 2011 04:29 AM
jdmstylez16
Oct 28, 2007 02:39 PM
mjrage
May 31, 2004 09:48 PM
