check engine light..please help
Old Jan 24, 2008 | 04:08 PM
lsvtec2000's Avatar
Default check engine light..please help
im clueless about what is goin on with my car..so im driving down the street and all of a sudden im getting no power to the car when i step on the gas..then i start pumping the gas a the start gettin power again..this went on for like thirty seconds..the car was still on motor was still running..everything normal but when i step down on the gas nothing was happening..no rpms no nothing..i was jus cruising...then a the check engine light comes up and my car is fine..it drove fine and everything..the thing is when i turn my car off and let it seat..and start it to drive again..no problems..then all a sudden the same **** happens again..dnt know whats wrong..hopefully someone can help..o yea could the crank position sensor have something to do with this..someone please help me out
Old Jan 25, 2008 | 12:18 PM
thesmogman's Avatar
Default Re: check engine light..please help (lsvtec2000)
Pull the code and start from there.
If it is a 2000 you are OBDII and some auto parts stores will pull the codes for free.
Or throw a mechanic a $20 or so.
The code will tell you if it is the crank sensor or not.
lsvtec2000
Jan 24, 2008 10:45 PM
lsvtec2000
Jan 24, 2008 07:54 PM
kinvid22
Jan 20, 2007 09:17 AM
LScivic_wpg
May 27, 2006 10:10 PM
