COOLANT TEMP. SENSOR
Old Jan 24, 2008 | 04:04 PM
Valetin831's Avatar
Default COOLANT TEMP. SENSOR
WHERE IS THE COOLANT TEMPERATURE SENSOR LOCATED? DOES ANYONE HAVE A DIAGRAM OF WHERE ITS AT. THANKS.
Old Jan 24, 2008 | 04:33 PM
oreopeete's Avatar
Default Re: COOLANT TEMP. SENSOR (Valetin831)
in the head. look for the upper radiator hose. follow that hose to the head, the temp sensor will be on the side of the head that the rad hose goes into. (passenger side) although... i though there were actually 2 temp sensors. one has the one wire for the gauge on your dash, and the other is the one right behind it that has 2 wires going to it, actually telling your ecu the temp. correct me if im wrong..
Old Jan 24, 2008 | 05:13 PM
Crx Jimmy's Avatar
Default Re: COOLANT TEMP. SENSOR (oreopeete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oreopeete &raquo;</TD></TR><TR><TD CLASS="quote">in the head. look for the upper radiator hose. follow that hose to the head, the temp sensor will be on the side of the head that the rad hose goes into. (passenger side) although... i though there were actually 2 temp sensors. one has the one wire for the gauge on your dash, and the other is the one right behind it that has 2 wires going to it, actually telling your ecu the temp. correct me if im wrong..</TD></TR></TABLE>
correct
95DC2GS-R
Jul 1, 2010 08:05 PM
hatchyksp
Mar 26, 2009 08:34 AM
mopar junkie
Jan 13, 2007 06:37 AM
asiansgoweeee
Nov 3, 2004 08:03 AM
2000_Civic_Si
Apr 3, 2002 09:03 AM
