zc problem
Old Jan 24, 2008 | 02:36 PM
ef_zc's Avatar
Default zc problem
i have a dual cam zc and i just bought the 89 integra spark plug wires and they don't go all the in they sit about an inch out anyone no way thanks
Old Jan 24, 2008 | 04:59 PM
ef_zc's Avatar
Default Re: zc problem (ef_zc)
anybody i know a lot of u guys/girls have the zc
Old Jan 24, 2008 | 05:08 PM
Crx Jimmy's Avatar
Sorry I dont have any first hand zc experience but I thought the stock civic sohc ones fit?
Old Jan 25, 2008 | 06:40 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_zc &raquo;</TD></TR><TR><TD CLASS="quote">i have a dual cam zc and i just bought the 89 integra spark plug wires and they don't go all the in they sit about an inch out anyone no way thanks </TD></TR></TABLE>89 Integra wires fit perfectly - sounds like you may have 90 and up Integra B18 wires and not 89 D16A1 wires - B18 wires will be about an inch up, like this:
Old Jan 25, 2008 | 05:51 PM
ef_zc's Avatar
Default Re: zc problem (jlicrx)
ya they sit like that
Old Jan 25, 2008 | 06:42 PM
ef_zc's Avatar
i looked up the part num the ones i got are bosch and the num is 09190 and it says they are for 89 integra and why would there be 5 wires in side
Old Jan 25, 2008 | 06:49 PM
crxgator's Avatar
sounds like they were mislabeled...return them, and order a set of NGK wires online for about $35...
Old Jan 25, 2008 | 06:50 PM
ef_zc's Avatar
Default Re: zc problem (crxgator)
ya i'll try that thanks
Old Jan 26, 2008 | 09:05 AM
hondasaurusrex's Avatar
when i got mine i actually got 6 wires...the other 2 i assume are for some other car that uses the same length wires/boots but had an external coil...
Old Jan 26, 2008 | 03:16 PM
EFOwNzALL's Avatar
my ZC needed the D16A6 wires n they fit perfectly...dont kno if its the same for u
do u have the JDM DOHC ZC, or the USDM ZC? the usdm ZC has a brown valve cover, the JDm has a black finish valve cover, alot ov ppl want the jdm over the usdm, so sum homosexual people will paint them black, more than likely im wrong, just askn...good luck
Old Jan 26, 2008 | 03:19 PM
crxgator's Avatar
Default Re: zc problem (EFOwNzALL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFOwNzALL &raquo;</TD></TR><TR><TD CLASS="quote">my ZC needed the D16A6 wires n they fit perfectly...dont kno if its the same for u
do u have the JDM DOHC ZC, or the USDM ZC? the usdm ZC has a brown valve cover, the JDm has a black finish valve cover, alot ov ppl want the jdm over the usdm, so sum homosexual people will paint them black, more than likely im wrong, just askn...good luck</TD></TR></TABLE>
yeah, youre very wrong...
Old Jan 26, 2008 | 04:11 PM
ef_zc's Avatar
i got them to fit they had a cut away mark and then i had to pull the wire up so it would sit good and my valve cover is red and i don't think it has been painted doesn't look like it anyways but thanks for your help
Old Jan 26, 2008 | 11:19 PM
welfarepc's Avatar
i dont think any zc's came with red vc's... hmm
Old Jan 27, 2008 | 07:46 AM
ef_zc's Avatar
Default Re: (welfarepc)
really i thought they did
Old Jan 27, 2008 | 07:50 AM
crxgator's Avatar
Default Re: (ef_zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_zc &raquo;</TD></TR><TR><TD CLASS="quote">really i thought they did
nope, just brown and black...
JDM89CrXZc
Oct 22, 2007 09:58 AM
Civiclized
Apr 25, 2007 07:48 AM
Mike@K-Tuned
Mar 22, 2006 08:05 PM
therealciviczc
Jul 11, 2003 06:16 PM
1990hondaHF
11
Sep 25, 2002 09:45 AM
