2005 RSX cabin filter replacement???
The owners manual spells out the proceedure quite nicely. Basically you remove the "stoppers" for the glove box and drop it out of the way. This allows access to the air duct cover that conceals the filters. It's pretty straight forward from there.
Thank you guys. Now the only thing I need to replace is my intake filter, I looked at it the other day but is not straight forward, like the gsr, need to remove more stuff before can access the intake filter, is there a trick on accessing this filter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 »</TD></TR><TR><TD CLASS="quote">Thank you guys. Now the only thing I need to replace is my intake filter, I looked at it the other day but is not straight forward, like the gsr, need to remove more stuff before can access the intake filter, is there a trick on accessing this filter?</TD></TR></TABLE>
Yeah trick is you remove all the screws on the top around the intake with a philips and then loosen the clamp on the intake and valve cover breather....that is all.
