Slop in 1.5 Engine
Old Jan 24, 2008 | 10:34 AM
dbailey's Avatar
Default Slop in 1.5 Engine
Guys I have a 90 Civic sedan with the 1.5 in it and when I start it first thing in the morning, it sounds pretty sloppy and was wondering what it might be. Got right at 180,000 miles on her. When it warms up it pretty much goes away. Would the valves needing adjustment do that or is it worse (rod bearings/rods)? Any ideas/suggestions would be awesome. Thanks.
Old Jan 24, 2008 | 11:40 AM
dbailey's Avatar
Default Re: Slop in 1.5 Engine (dbailey)
It's kind of a clattering sound. Will valves make that kind of sound and then quiet down after it warms up?
Old Jan 24, 2008 | 11:55 AM
wiZCo's Avatar
Stouts 'n' Scotch
Yessir, that would be my first guess. Adjust the valves to spec and see it it helps. You may also want to try cleaning out your IACV/EACV while you're at it and flush the coolant system if it hasn't been done for a while.
Old Jan 24, 2008 | 12:03 PM
HiProfile's Avatar
The way to tell if your bearings are going is to put a pressure gauge on the motor. 10-15psi at 750rpm idle, 50psi >3k rpm. Cold lifters that need adjustment will be very loud when cold. They also reduce power/gas milage, so thats another reason to adjust them.
Old Jan 24, 2008 | 12:07 PM
dbailey's Avatar
Default Re: Slop in 1.5 Engine (HiProfile)
How do you clean the IACV valve? Hey thanks guys for the suggestions.
Old Jan 24, 2008 | 12:09 PM
dbailey's Avatar
Also, I know this is a really dumb question but I want to make sure, you put the pressure gauge in one of the spark plug holes right? If so, does it matter which one or check all 4? Thanks again.
Nice Fit
Honda Fit
Feb 17, 2009 10:12 PM
littleblue
Aug 10, 2008 05:08 PM
dbailey
Jan 25, 2008 03:33 AM
2civic3
10
Sep 25, 2006 09:20 PM
Flux
Apr 15, 2004 07:25 PM
