APR strut bar/Poly bushings
Old Jan 24, 2008 | 10:10 AM
On1ACCORD's Avatar
Default APR strut bar/Poly bushings
I wanted to 2 know if any '97 Accord owners have installed a(n) APR strut bar and if so could u post pics? Plus i recently bought a complete front and rear poly kit for my Accord. Does the poly kit make ur suspension squeak 1nce installed? thankx!
Old Jan 24, 2008 | 10:32 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: APR strut bar/Poly bushings (On1ACCORD)
I don't know what the APR strut bar looks like but I can't assume it's any different than the rest out there.
the polyurethane bushing kit could make your suspension squeak if you don't lubricate them correctly. But AFAIK it shouldn't squeak if installed correctly.
Old Jan 24, 2008 | 11:00 AM
On1ACCORD's Avatar
Default Re: APR strut bar/Poly bushings (TouringAccord)
thanx bro.
Old Jan 24, 2008 | 11:04 AM
SuShiBoiiii's Avatar
Old Jan 25, 2008 | 10:20 AM
On1ACCORD's Avatar
Default Re: APR strut bar/Poly bushings (SuShiBoiiii)
gud lookn on da pic sush, does it really fit '97 exl? the blue endz look like it wouldn't fit. The '97 ex bay has a(n) electrical box on the left & sum metal lines on the rite that seem to be n da way of the 3 bolts that hold the shock(s) nplace, like the endz of da strut bar would need 2 b flat. I LUV THIS STRUT BAR!!!! but bewildered @ da moment.
Old Jan 25, 2008 | 10:33 AM
H-T Order of Merit
You are talking about the ABS fuse box and ABS brake lines. Not sure if it would have clearance issues or not. I never put a strut bar on my Accord.
Old Jan 25, 2008 | 03:47 PM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by On1ACCORD &raquo;</TD></TR><TR><TD CLASS="quote">gud lookn on da pic sush, does it really fit '97 exl? the blue endz look like it wouldn't fit. The '97 ex bay has a(n) electrical box on the left & sum metal lines on the rite that seem to be n da way of the 3 bolts that hold the shock(s) nplace, like the endz of da strut bar would need 2 b flat. I LUV THIS STRUT BAR!!!! but bewildered @ da moment. </TD></TR></TABLE>
Que?
Old Jan 25, 2008 | 04:56 PM
gianinline's Avatar
Generic strut bars and cusco, tanabe or whatever other brand you could find, you will always be very close the fuse box and those 2 hoses small hoses over the driver's side strut tower.
Old Jan 25, 2008 | 11:31 PM
Default Re: (gianinline)
sometimes you just need to remove the bolt to give it some give and then put the bar on then the bolt
Old Jan 26, 2008 | 11:04 AM
street_accord94's Avatar
I have been using poly bushings for at least 3 years through NE winters and they haven't given me any issues with squeaking. they are a PITA to install, and depending on what kit you purchased, you may need additional components to replace all your rubber bushings.
Old Jan 29, 2008 | 08:57 AM
On1ACCORD's Avatar
Default Re: APR strut bar/Poly bushings (street_accord94)
my front kit are the Energy Suspension Master set, rear: Uerthanane rear upper&lower set, plus i purchased xtra grease 4 da install (so everything is properly lubed 2 prevent squeakin'); so there could b more componets needed outside the polykits that i purchased? if so any idea whut they may b?
Old Jan 29, 2008 | 02:49 PM
you'll probably want to measure the bushing size for the rear lower strut mounts, rear coil spring isolators, and rear ball joint boots, so everything is poly rather than having some rubber bushings left. While you're at it, you ay also want to change your rubber bushings in the upper strut mounts to poly. you can simply look for "universal" bushings from prothane or es that fit the dimensions.
253cd5accord
Jan 22, 2010 01:02 PM
ZUL8R
May 1, 2008 11:49 PM
DrewWi22
Jul 4, 2005 11:34 AM
2000Accord5sp
Oct 17, 2002 04:11 AM
ChuuungDaaavid
Jul 7, 2002 03:52 PM
