Injector Wire ground location???
Old Jan 24, 2008 | 07:54 AM
BfromSD's Avatar
Default Injector Wire ground location???
Im refureing to the Yellow/black striped wires that are on the injector clips ... tested them for continuity with a volt meter and they are not grounded , were is that ground located?
Car: 97ek with a jdm b16 still using the Jdm engine harness but cut to fit a LHD car.
- Also the only grounds I have hooked up are the main engine harness ground located next to the ECU and the Fuel pump ground by the drivers seat.
Old Jan 24, 2008 | 07:56 AM
BfromSD's Avatar
Default Re: Injector Wire ground location??? (BfromSD)
Tested for continuity with a volt meter on my buddys car at the injector clips and their was a closed circuit ...
Old Jan 24, 2008 | 08:14 AM
thesmogman's Avatar
The ECU grounds them. You get power from the main relay to the resistor box then the injectors. Then from the injectors to the ECU.
Basically the ECU is a groundside switch. You should have 4 injector pinouts on the ECU connector.
Old Jan 24, 2008 | 02:46 PM
BfromSD's Avatar
Default Re: Injector Wire ground location??? (thesmogman)
Using ECU pin out diagram found in this link https://honda-tech.com/zerothread?id=1791725 I could not find were the injector ground wires feed the ecu , only the power wires are shown.
Were do the injector wire grounds(yellow/black strip) go to ?
...What do you suggest I do next to trouble shoot ?
Old Jan 24, 2008 | 03:39 PM
thesmogman's Avatar
Connector A pin's 1234 are 4321 injectors.
These four should be open = no continuity thus ground switched. Now when the injector is switched on you would see continuity to ground on these wires.
At least that is the theory I was taught.
Old Jan 24, 2008 | 05:50 PM
GhostAccord's Avatar
A YEL/BLK wire should never be a ground wire. They are your (+) wires. They should be connected to your resistor box if you have low impedance (peak & hold) injectors. Or strait to the YEL/BLK wire coming from the PGMFI Main relay if you have high impedance (saturated) injectors. This is what thesmogman posted above but in the reverse.
The ground wires are the 4 wires that go to the pins on the ECU as thesmogman posted.
salemned
Sep 7, 2017 12:13 PM
carlos8
Dec 19, 2016 07:11 PM
glenb902
Jan 4, 2016 05:45 PM
Deo
Jan 24, 2008 06:31 AM
underpressure02
Apr 7, 2007 05:10 AM
