evap purge solenoid?????
Old Jan 23, 2008 | 03:53 PM
nfereorhatch's Avatar
Default evap purge solenoid?????
Today i broke the top off the purge solenoid while i was sliding my engine under the car, do i have to have it? The d16z6 is going in my 90 sedan and this is the only hold up left. I need to know if i need to find a new one or if i will be alright.
Old Jan 23, 2008 | 04:02 PM
thesmogman's Avatar
Default Re: evap purge solenoid????? (nfereorhatch)
Yes. Keep the solenoid plugged in (electrically) and pull both hoses going to it and plug them.
Just needed to purge the evap system not for running the car.
Old Jan 23, 2008 | 04:44 PM
Default Re: evap purge solenoid????? (thesmogman)
Thanks, read over several archived threads but wanted a definitive answer.
Old Jan 23, 2008 | 05:18 PM
Crx Jimmy's Avatar
No, that is not correct you can unplug it as well, it does NOT throw any code. I took mine out when I installed a catch can and removed the charcoal canister
Old Feb 12, 2008 | 10:13 PM
obuhmyuh's Avatar
Default Re: evap purge solenoid????? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">No, that is not correct you can unplug it as well, it does NOT throw any code. I took mine out when I installed a catch can and removed the charcoal canister</TD></TR></TABLE>
no code 92?
Old Feb 14, 2008 | 05:47 AM
StorminMatt's Avatar
Default Re: evap purge solenoid????? (d[sick]sTeena)
Code 92 = OBDII. This is nothing to worry about on a CRX.
Old Mar 13, 2009 | 10:24 PM
FOMULA91's Avatar
Which 2 wire did you solder? I did mine but not sure if I did it right since it doesn't throw a code. I know u use one of the black one but not sure with the other one.
Superdragr45
Jan 23, 2006 02:32 PM
AMG
Sep 2, 2003 07:03 AM
96tegsr
Aug 22, 2003 08:37 AM
WhItE99CiViC
Apr 10, 2003 03:54 PM
speedymon
Jul 16, 2002 08:39 PM
