b18 swap into a 1990 civic hatch
i was wondering what all would go into swapping a b18 into a 1990 civic hatch.. is it a direct swap? or will I have to do some fabrication on the mounts
ok your gonna get SEARCH SEARCH bla bla, but ill help you. youll need linkage, i just bought some from "PerformanceCloseout" a member on here for 130, there avid, and some mounts obviously. your harness you can use unless your using vtec. youll have to wire it in. axles and rear t bracket. essentials then your ecu of course. dont forget to bang your inner frame in to except the alternator, and ive seen shaven front motor mounts as well. but do some searching becus ive made this same thread about a week or 2 ago heh good luck man
quick1.6
15
Feb 13, 2010 08:16 PM
dadsvtechonda
Jul 31, 2007 05:45 PM
