Honda S2000 Honda S2000
2005 rear differential how to remove output shaft??????? help
Old Jan 23, 2008 | 01:01 PM
bajramx's Avatar
Default 2005 rear differential how to remove output shaft??????? help
Whats up guys i was wondering if anyone could tell me how to remove the output shaft from a 2005 rear differential? Im tring to put this in my ap1 and i noticed the shaft that connects to the driveshaft the screws are different from the ap1 so i wanted to change the output shaft on the ap2 rear, or would it be easier to just drill the driveshaft a lil bigger so that i can fit the screws threw it??
Let me know what to do
Thanks
Old Jan 23, 2008 | 03:03 PM
kickz's Avatar
Default Re: 2005 rear differential how to remove output shaft??????? help (bajramx)
hey which one the 14mm bolts ?
would probably be easier to get new bolts for the ap2 rear drive shafts
Old Jan 23, 2008 | 03:50 PM
bajramx's Avatar
Default Re: 2005 rear differential how to remove output shaft??????? help (kickz)
its the bolts that connect the drive shaft to the rear differential i bought the ap2 bolts from Honda but they don't fit threw my drive shaft they are too big so that's y i was asking if i should drill the holes bigger on the drive shaft im not sure if that's ok to do what do u think?
Old Jan 23, 2008 | 05:28 PM
Sideways's Avatar
You need to install an AP-1 flange on the rearend (from your old rear end maybe) if you are using an AP-1 drive shaft with the AP-2 rearend. If you have the AP-2 driveshaft then you need a transmission ap-2 flange to complete the package.
gort
Feb 5, 2017 02:34 PM
Greatness
Jan 15, 2010 05:21 PM
Rhymenoceros
Nov 22, 2007 12:16 PM
Icemanxxxv
Oct 17, 2005 09:48 AM
