V-Tec wiring help
Old Jan 23, 2008 | 11:57 AM
nitewolf's Avatar
Default V-Tec wiring help
90 dx 4dr*ED3* i got a 00y8 and a chipped pm6 ecu i need help wiring v-tec. .
thanks in advance
Modified by nitewolf at 2:51 PM 1/23/2008
Modified by nitewolf at 8:43 PM 1/24/2008
Old Jan 23, 2008 | 01:51 PM
nitewolf's Avatar
Default Re: V-Tec wiring help (nitewolf)
bump can i get some help
Old Jan 23, 2008 | 05:07 PM
intense4thgen's Avatar
have you done a MPFI conversion? you will need it to use that computer.
a4-vtec solonid
d6-vtec pressure swich (also black to groung on the swich)
http://hybrid.honda-perf.org/tech/4gdxtozc.html<<<<<< here is a link to the multiport swap too!!!
Old Jan 23, 2008 | 08:02 PM
nitewolf's Avatar
Default Re: V-Tec wiring help (intense4thgen)
yeah my multi swap is done i jux never had a ecu wit with v-tec basemap jux got one and i want v-tec now thankz again
Old Jan 23, 2008 | 08:05 PM
tnez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitewolf &raquo;</TD></TR><TR><TD CLASS="quote">yeah my multi swap is done i jux never had a ecu wit with v-tec basemap jux got one and i want v-tec now thankz again</TD></TR></TABLE>
...so are you talking about hard-wiring your vtec?
Old Jan 23, 2008 | 08:29 PM
nitewolf's Avatar
Default Re: V-Tec wiring help (tnez)
jux wanted to know what wires went to the ecu
Old Jan 23, 2008 | 08:43 PM
nitewolf's Avatar
cant find a picture of a wiring diagram
Old Jan 23, 2008 | 09:06 PM
mario_pic's Avatar
u can to a shift lignt to activate ur vtec only problem is that if ur doing a rev start vtec will hit lol u got to take the shift light on a after market tack and wire it to a low voltage switch relay that has a low voltage switch with a high voltage relay then u splice a 12 volt wire and hook it up to the relay and the other to the vtec single wire then u just need to set where the shift light comes on and ur all good lol what i did was i put writeing on my shift light that reads VTEC lol beat that vtec light lol let me know if u need help
Old Jan 24, 2008 | 06:56 AM
nitewolf's Avatar
Default Re: V-Tec wiring help (mario_pic)
well need some help locating a6(to vtec sylo.) on ecu? first plug 6pins over? And d6?(to vtecpres.switch)
Old Jan 24, 2008 | 10:38 AM
HondaPartsHero's Avatar
Technical Hero
there is no placement on a PM6 ECU for VTEC, do you mean PR3 or PWO?
Old Jan 24, 2008 | 11:19 AM
nitewolf's Avatar
Default Re: V-Tec wiring help (HondaPartsHero)
there is no placement? well i guess im stucc then but my pm6 has a twicced y8 base map. any other sugestions
Old Jan 24, 2008 | 11:28 AM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic &raquo;</TD></TR><TR><TD CLASS="quote">u can to a shift lignt to activate ur vtec only problem is that if ur doing a rev start vtec will hit lol u got to take the shift light on a after market tack and wire it to a low voltage switch relay that has a low voltage switch with a high voltage relay then u splice a 12 volt wire and hook it up to the relay and the other to the vtec single wire then u just need to set where the shift light comes on and ur all good lol what i did was i put writeing on my shift light that reads VTEC lol beat that vtec light lol let me know if u need help</TD></TR></TABLE>
I'm sorry but reading that makes me think you are some kind of unintelligent robot
Old Jan 24, 2008 | 12:11 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitewolf &raquo;</TD></TR><TR><TD CLASS="quote">there is no placement? well i guess im stucc then but my pm6 has a twicced y8 base map. any other sugestions</TD></TR></TABLE>
"twicced"??? Thats not even a word.
Your PM6 can have a fuel map compatable with a D16Y8, but it has no ability to give you the dual fuel/ignition maps needed for proper VTEC functionality, nor can it activate VTEC w/o rewiring an automatic-based PM6 to use the automatic lock-up solenoid feature for VTEC. That would also require the proper ECU software to use that feature.
In other words, a PM6 will not give you VTEC. It will be difficult w/o lots of rigging, and will require an RPM switch or heavy ecu modifications.
Old Jan 24, 2008 | 06:43 PM
nitewolf's Avatar
Default Re: V-Tec wiring help (HiProfile)
jux because i spelled it diffrent does not mean it aint a word. and the pm6 is chipped for single vtec turbo.
Old Jan 24, 2008 | 06:47 PM
nitewolf's Avatar
i spelled it a diffrent way that does not mean it aint a word. but i guess the pm6 was chipped for single v turbo. thanks again guys
Old Jan 24, 2008 | 07:00 PM
whiteknightef's Avatar
do you even read the posts?
Old Jan 24, 2008 | 07:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitewolf &raquo;</TD></TR><TR><TD CLASS="quote">jux because i spelled it diffrent does not mean it aint a word. and the pm6 is chipped for single vtec turbo. </TD></TR></TABLE>
no such thing. You cant chip the pm6 for vtec, im pretty sure on that.
Get a p28 and call it a day.
Old Jan 24, 2008 | 07:41 PM
nitewolf's Avatar
Default Re: V-Tec wiring help (whiteknightef)
no jumpe harness. im sketchy on those the wires brake off sometimes but thats the easyiest way
Old Jan 24, 2008 | 07:46 PM
nitewolf's Avatar
getting a chipped pr3 tonight..
Old Jan 25, 2008 | 09:11 PM
nitewolf's Avatar
so much for that pr3 makes mi car idle at 4grand. but i was reading in this article https://honda-tech.com/zerothread?id=651007 and there sayen how there going to chip there pm6 for v-tec
ClutchPapi
May 8, 2013 04:41 PM
fab2278
Honda Civic (2001 - 2005)
Apr 21, 2011 01:08 PM
technine
Jan 17, 2008 10:43 AM
wzachmorris69
Nov 6, 2006 12:26 PM
OnPointAccord
Oct 6, 2005 01:47 AM
