turboing a base rsx
Old Jan 22, 2008 | 07:53 PM
kTmsKr's Avatar
Default turboing a base rsx
what does or doesn't have to be done to the motor to do this?
Old Jan 22, 2008 | 08:01 PM
iVteCmMdc5's Avatar
Default Re: turboing a base rsx (kTmsKr)
well it depends if u wanna turbo it with stock internals see how long it lasts blow it up and redo it or just do it right from the start and not have to worry about it
U get what u pay for !!!!! <<<<
Old Jan 22, 2008 | 08:03 PM
kTmsKr's Avatar
thats what im asking is what would be the right way to do it
Old Jan 22, 2008 | 08:11 PM
iVteCmMdc5's Avatar
Default Re: (kTmsKr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kTmsKr &raquo;</TD></TR><TR><TD CLASS="quote">thats what im asking is what would be the right way to do it
well i dk how much your looking to spend but if u got deep pockets and ur looking to have a pretty reliable turbo car build the motor up (pistons,cams,vavle springs etc) Put the turbo on get a good tune job and u should be ok and ur car should be reliable
Old Jan 22, 2008 | 08:20 PM
kTmsKr's Avatar
just what ever it takes to do it right i can't stand for something to f*up..i've heard about if you turbo it causes alot of problems as far as driving it on a daily basis but as of right now just planning for the future thanks for answering my question
Old Jan 22, 2008 | 08:23 PM
iVteCmMdc5's Avatar
no promb GLAD TO HELP
Old Jan 22, 2008 | 08:37 PM
lilbinky's Avatar
Just a little advice, try and get everything as close to new as you can and also buy from reputable people. It is a lot of fun and a LOT more heartache. I tried to piece together a turbo car one time and it was WAY more than I thought I was gonna get into.
Just get a good mani, turbo, and tune the **** out of it...
All the other **** can be second rate but plan on upgradeing it. Also don't forget things like clutch and axles. I would hate to see you with snapped axles and a slipping clutch, running 15's...
Good luck with the build and just remember to buildthis car wisely because the motor is not that cheap to replace!
Old Jan 22, 2008 | 08:38 PM
iVteCmMdc5's Avatar
Default Re: (lilbinky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilbinky &raquo;</TD></TR><TR><TD CLASS="quote">Just a little advice, try and get everything asclose to new as you can and also buy from reputable people. It is a lot of fun and a LOT more heartache. I tried to piece together a turbo car on time and it was WAY more tha I thought I was gonna get into.
Good luck with the build and just remember to buildthis car wisely because the motor is not that cheap to replace!</TD></TR></TABLE>
I like the way u think
Old Jan 23, 2008 | 06:03 AM
blueshark123's Avatar
Default Re: (iVteCmMdc5)
Is this an auto or 5-speed? What are your power/ET goals? Without these goals we cant tell you what to get. Also stock axles are fine. I ran 650whp on stock axles. The trans will take a crap before the axles.
Old Jan 23, 2008 | 12:40 PM
kprsx's Avatar
What kits are you going with?
Old Jan 23, 2008 | 01:30 PM
jdmjunkie8's Avatar
Default Re: (blueshark123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueshark123 &raquo;</TD></TR><TR><TD CLASS="quote">Is this an auto or 5-speed? What are your power/ET goals? Without these goals we cant tell you what to get. Also stock axles are fine. I ran 650whp on stock axles. The trans will take a crap before the axles.</TD></TR></TABLE>
damn
Old Jan 23, 2008 | 01:53 PM
RedDC5's Avatar
Default Re: (jdmjunkie8)
the good thing bout a base....lower compression! should make it a bit easier
Old Jan 23, 2008 | 10:17 PM
kTmsKr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilbinky &raquo;</TD></TR><TR><TD CLASS="quote">Just a little advice, try and get everything as close to new as you can and also buy from reputable people. It is a lot of fun and a LOT more heartache. I tried to piece together a turbo car one time and it was WAY more than I thought I was gonna get into.
hell of a answer
its a 5 speed i'd like to atleast get 220-230hp out of it
Old Jan 24, 2008 | 01:44 AM
JCL's Avatar
JCL
220-230? then why would u have to worry.. unless thats all the power goals u want NOW but in the FUTURE u want more then i would see a point in building. a decent greddy kit w/ fmic should not run more than 2700.
btw alota ppl do daily drive their S motors at 450whp 15 psi.
Old Jan 24, 2008 | 04:56 AM
hell of a answer
its a 5 speed i'd like to atleast get 220-230hp out of it </TD></TR></TABLE>
Supercharge it and call it a day. No need to build the motor....
Old Jan 24, 2008 | 08:23 AM
kTmsKr's Avatar
yea i thought about superchargin it also im kinda stuck between a rock and a hard place cause i know i could just throw a supercharger on and go but i know its gonna take some work to turbo but it just sounds sooo much nicer
Old Jan 24, 2008 | 11:57 AM
dan12288's Avatar
wow thats a lot of whp, by the way how much money did you drop to get that set up and what set up did you use?
Old Jan 24, 2008 | 11:59 AM
dan12288's Avatar
Default Re: (JCL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCL &raquo;</TD></TR><TR><TD CLASS="quote">220-230? then why would u have to worry.. unless thats all the power goals u want NOW but in the FUTURE u want more then i would see a point in building. a decent greddy kit w/ fmic should not run more than 2700.
btw alota ppl do daily drive their S motors at 450whp 15 psi. </TD></TR></TABLE>
how would the gas be at 450whp 15psi? i would do that myself any links to find this information?
Old Jan 24, 2008 | 12:11 PM
Default Re: (dan12288)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan12288 &raquo;</TD></TR><TR><TD CLASS="quote">
how would the gas be at 450whp 15psi? i would do that myself any links to find this information? </TD></TR></TABLE>
What do you mean how would the gas be at? If you are referring to octane, I run 460whp on 93 octane.
wow thats a lot of whp, by the way how much money did you drop to get that set up and what set up did you use?</TD></TR></TABLE>
http://www.k20a.org/forum/showthread.php?t=29956
Old Jan 24, 2008 | 03:41 PM
dan12288's Avatar
Very nice man, i ment to say hows the mpg at 15 psi
Old Jan 25, 2008 | 07:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan12288 &raquo;</TD></TR><TR><TD CLASS="quote">Very nice man, i ment to say hows the mpg at 15 psi</TD></TR></TABLE>
I get 18-20 but whenever I drive it Im in boost lol. Ive never really babied the car to see what it can get. I sure 31+mpg is definitely possible.
Old Jan 25, 2008 | 01:37 PM
dan12288's Avatar
I get 18-20 but whenever I drive it Im in boost lol. Ive never really babied the car to see what it can get. I sure 31+mpg is definitely possible.</TD></TR></TABLE>
lol man i am looking to start a set up like yours, dont think i would baby it either with a turbo, but i do see it doing 31+ since the turbo will make it breath better.
Old Jan 26, 2008 | 11:41 AM
kTmsKr's Avatar
yea i would really like to keep decent mpg especially if gas prices don't go down im tired of paying 3$ a gallon its
MesicanRSX04
Aug 23, 2007 07:42 AM
racereaper7
Sep 26, 2006 05:41 PM
wish_i_was_h22a
Sep 2, 2006 06:14 PM
Jason W
Apr 4, 2002 02:09 PM
