05 Civic SI headlight question
Has anybody had an issue with their headlight fogging up real bad? My sister has had this car since new and had the light replaced three times and it keeps getting fogged up. The dealer does not know why it keeps doing it. I think the seal is not very good just wanted to get other opinions.
It sounds like a bad seal but I am not sure, unless you have a Canadian SI this isn't the right Forum for you though. You need to go to https://honda-tech.com/zeroforum/32 they would pry be able to tell you if it is a common problem or not.
I would continue taking it back to the dealer until it is resolved. I had a defective housing that fogged up, had it replaced and it did it again, I returned it the next day and come to find out the installers neglected to put in the rubber rings around the bulbs. Look at the rear of the housings with the bulb in. If you can see silver (the reflectors inside the housing around the bulb, then they also forgot to put in the rubber seal. Check it out, but the lights should not fog unless there is a seal leak, so have them fix it correctly.
