Replacing bushings that came with th Blox LCA
Old Jan 22, 2008 | 11:03 AM
hybrid90's Avatar
Default Replacing bushings that came with th Blox LCA
I bought a set of Blox LCA's for my DA and was wondering if it's a good idea to replace the bushings with the ES ones or should I just leave it as is and install it?
Just trying to find out with is the better choice.. the Blox bushings or the ES ones for the LCA... thanks in advance
Old Jan 22, 2008 | 02:31 PM
qazaq's Avatar
Default Re: Replacing bushings that came with th Blox LCA (hybrid90)
i just changed mine, on blox lcas to ES
Old Jan 22, 2008 | 02:53 PM
ekhunter's Avatar
dont worry about it man, unless you are autocrossing you dont need stiffer bushings, plus you have to have them pressed in and out by a machine shop, or its a pain teH dick hole
Modified by ekhunter at 4:54 PM 1/22/2008
Old Jan 22, 2008 | 03:01 PM
qazaq's Avatar
Default Re: (ekhunter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhunter &raquo;</TD></TR><TR><TD CLASS="quote">dont worry about it man, unless you are autocrossing you dont need stiffer bushings, plus you have to have them pressed in and out by a machine shop, or its a pain the the dick hole</TD></TR></TABLE>
indeed. i used two sockets one 1" and another like 32 mm and a long screw with a nut; pull those bitches right out. still took quiet bit of time.
if your bushing on blox lcas are fine, just leave them there
Old Jan 22, 2008 | 03:13 PM
all-mtr-teg's Avatar
Default Re: (qazaq)
I used a ball joint installation tool, big as clamp ftw
Old Jan 22, 2008 | 03:31 PM
hybrid90's Avatar
Default Re: (all-mtr-teg)
Cool! Thanks guys! Just wanted to make sure before installing the lca's
92egSnatch
Honda Civic (2001 - 2005)
Apr 14, 2008 09:18 AM
OMG WTF
Suspension & Brakes
Jul 20, 2006 07:49 PM
sicegcivic
Mar 2, 2006 07:22 AM
TeaAddict
Dec 7, 2004 07:21 PM
Urban Business
Apr 21, 2003 07:19 PM
