AC PROBLEM
my teg is just blowing cold air and what not. even when i put it on for hot. it i just dumpin cold air left and right. what is wrong with that coolant is filled to the top. the only thind done to thiss car would be cold air intake would that be the reason why the car is dumping out only cold air. i dunno it's winter outide and i dont want to tinker with it too much... too damn cold
i'll def check it out when there is light outside. cant see anything with the weather and what not... yeah this teg is just pretty ghey. no matter what/how long i run it it is just dumping out cold... thanks for the tip
I was having that problem last week. But check this out. This week i got an oil change and they topped of my coolant and now it works good as hell. Just double check your coolant level. Use a funnel, fill it up, let it run for a bit and let the air bubbles filter out, then top if off again. That should help. Did for me.
Prevail
Jun 22, 2003 06:33 PM
