929 to 945 swap
is it worth it?
For the money you spend on the swap you could probably just bore your 929 out to a 954.
And ultimately you're talking about 25cc.
I'm not saying don't do the swap because I don't know if it's a simple process or not, i'm just wondering if it's worth the trouble.
cbr929rr
cbr954rr
Looks like there's a difference, but is it noticeable on the street?
cbr929rr
cbr954rr
It's simple, for a motor swap, if you get a complete 945 motor and wiring harness, and the 954 gauges. The motor fits right in, all you need to do it add a few washers under the tank to raise it up slightly so the 954 airbox will fit.
IF you go cheap, it can be done, but you will have to splice some of the wiring together, make your airbox slightly larger to fit the 954 throttle bodies, get a 954 rectifier (it's a difference charging system than on the 929) and I'm sure a few other small things.
So if you can find a complete swap for cheap, then I say it may be worth it. If you can't find all the 954 parts, then it's probably too much of a hassle unless you have a ton of extra time.
Or you could just sell your 929 and buy a 954.
Modified by fatboy01 at 10:28 AM 1/22/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95JDM »</TD></TR><TR><TD CLASS="quote">im looking to do a 954 swap into my 929 frame anyone know some details? is it a simple thing or what ?</TD></TR></TABLE>
This is not a 1992 civic...
There are 1mm over pistons available for the 929, but its a bore and replate job since its nikasil. 1mm over is 954cc. I can get them if you want to go that way. Probably not worth it unless the engine needs taking down anyway.
well the reason im planning on it is becuase the bottom half of the 929 motor is smashed and i have a boy with a 954 motor so in any case i ethier buy a 954 or a 929 but its looking like i can get the 954 for cheaper
