90 civic with LS swap...... no start
Old Jan 22, 2008 | 06:25 AM
93NTEGLS's Avatar
Default 90 civic with LS swap...... no start
I jus swapped a LS in my ef and now its not starting. I am not getting any spark. I got a used obd1 distributor and converted it to obd0 by switching wires.
Orange.....orange
White.........white
Orange/blue.....orange/blue
White/blue......white/blue
Blue/green......blue/green
Blue/yellow......blue/yellow
Large white......yellow/green
Black/yellow......black/yellow
Blue......blue
I soldered and heat shrinked all connections. When cranking I get a code 4 for the crank sensor. First I thought that I had the 2 white wires wrong so I swtched them then it threw a code 8 for tdc position. I tripple checked everything to see if my wiring was right before and it was so I switched the white wires back. I'm thinking that its just a bad dizzy. Anyone had similar problems or input. Thanks
Old Jan 22, 2008 | 09:01 AM
tonio6403's Avatar
Default Re: 90 civic with LS swap...... no start (93NTEGLS)
yeah im lost on that too stuck right where u are i have to buy a volt meter to check and see if the dizzy is getting power from the batt. if not then im just gonna get a new one if so then im going to check the internal parts first but i have a 90 hatch with a 94 b18b motor in my hatch odb0 pr4 and odb0 dizzy them two white wires kinda threw me off for a sec cuz mine are both the same size
Old Jan 22, 2008 | 10:48 AM
93NTEGLS's Avatar
Default Re: 90 civic with LS swap...... no start (tonio6403)
yea the white wires on mine are the same size too but i also went by this and by the pinouts:
obd1
obd0
im pretty sure my wiring connections are correct and im getting a code 4
Old Jan 24, 2008 | 03:29 AM
tonio6403's Avatar
i took my dizzy cap and rotor off and found my coil with a bunch of cracks on it im pretty sure that is the problem i bought a new coil for it and im hooking it up sometime today
Old Jan 24, 2008 | 05:26 AM
93NTEGLS's Avatar
yea most likely thats your problem right there. good luck tho man. i got a distributor comin either today or tomorrow so once i get that im throwin it in asap and hopefully it fires right up. im getting fuel and compression is good, just no spark
Old Jan 24, 2008 | 05:57 AM
tonio6403's Avatar
yeah same to u and damn we both from bmore aint that a bish
Old Feb 3, 2008 | 05:14 AM
tonio6403's Avatar
u have an obd1 dizzy try switching the two white wires on the obd0 side
Old Feb 3, 2008 | 06:41 AM
pdotjones's Avatar
i threw a code 4, changed out the dizzy, and was on my way!
Old Feb 4, 2008 | 05:26 AM
93NTEGLS's Avatar
i bought a brand new obd0 distributor. but still no start. sounds like it wants to tho. i have to check over a couple more things tho
Old Feb 4, 2008 | 06:25 PM
tonio6403's Avatar
Default Re: (93NTEGLS)
yeah i just brought a new dizzy and fired it right up just watch for the two white wires if it dont start try switching them worked for me
JDMmadness
Apr 15, 2010 10:40 AM
blasterman87
Aug 28, 2009 12:23 PM
onefastek9
Sep 15, 2008 05:41 PM
CameBack_2_Hatch
Nov 20, 2004 01:49 PM
BoRiCuA
Jun 21, 2004 03:02 PM
