valve cover question
i have no idea why but for some reason the top right corner bolt wouldn't come off by itself... it seems to be pulling a stud out aswell, why would this be? and how do i fix it?
thanks
thanks
You could have bad threading on the top nut when it was installed..so when you start to retract, instead of turning the way its suppose to, it turns the whole stud. Kinda like cross-threading.
hmmm... so do you think if i grabbed ahold of the stud somehow and then tried to break apart the two that would work? maybe its just on there too tight
hmmm i didnt even think of that...
if it is coming out as one piece why cant i just take it out and put it back in as one piece good thinking!!!
definetly will do this in the morning i'll let you know if it works!
really im just making excuses in reality its just cold as ice outside and i really dont wanna hit up the garage... but i'm gonna go have a cigarette you gave me motivation to pull it off cuz you called me out!!! lol
lol but really still no luck with it i feel dumb cuz i mean its a valve cover nut i cant get off haha but it looks like there is another bolt under the VC nut that is free spinng but i cant get to it because the nut is ontop! it's like the nut is seized on to the stud or something... this is stupid
pretty simple actually seems like no one knew this little bit of knowledge haha if you loosen that stud enough it becomes unseated where it connects to the head for the valve cover to tighten down on.
once its unseated it will NOT come through the hole in the valve cover but if you take all the other ones off take the valve cover off the whole stud is still on there but off the head sooo with the valve cover being off you can simply grab it from the underside and the top and loosen it with a firm grip.
i got it all off and my valve cover is painted properly now!
thanks for all the help!
SuperSi
Jan 29, 2006 06:54 PM
lilxvtecxpwr
Aug 2, 2002 11:18 PM
