How hott does ur integra get?.. mine stays half way between C and the Half way Point
Old Jan 21, 2008 | 09:19 PM
Steven.'s Avatar
Default How hott does ur integra get?.. mine stays half way between C and the Half way Point
How hott does ur integra get.. mine stays half way between C and the Half way Point
Seeems more closer to C then half.. idk.. seems really reallly coool.. dunno if thats good? thought it was until i hear if it runs cool ur gas mileage goes down.. mine looks about 27 mpg if im not mistaken
Old Jan 21, 2008 | 09:24 PM
SuckMyDOHC's Avatar
Sounds like your thermostat is stuck open. Just replace it
Old Jan 21, 2008 | 09:29 PM
Steven.'s Avatar
Default Re: (SuckMyDOHC)
doesnt seem like its hurting.. cud be wrong at least its not overheating
Old Jan 21, 2008 | 09:36 PM
Mfoehrkolb's Avatar
mine stays right above 1/4 but doesnt hit 1/2.
Old Jan 21, 2008 | 09:50 PM
stock95LS's Avatar
Default Re: (Mfoehrkolb)
mine stays above the 1/4 and below the 1/2 mark
Old Jan 21, 2008 | 10:24 PM
kweezerkwee's Avatar
Default Re: (stock95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock95LS &raquo;</TD></TR><TR><TD CLASS="quote">mine stays above the 1/4 and below the 1/2 mark </TD></TR></TABLE>
Old Jan 22, 2008 | 12:16 AM
japanjay's Avatar
* B A N N E D *
If his thermostat was stuck open he would have no heat what so ever and the needle would "barely" move off the C.
Old Jan 22, 2008 | 06:04 AM
Junkie's Avatar
Mine gets to about 1/3 and then never budges unless I get it REALLY hot - meaning when it was running out of coolant due to a big hole in the radiator it would go up, but that's it.
Old Jan 22, 2008 | 10:15 AM
racebum's Avatar
Default Re: (Junkie)
Honda's in general run just under 1/2, my EG did, my teg does.
Old Jan 22, 2008 | 10:37 AM
thewrai6th's Avatar
Default Re: (idrivesideways)
If it's not going over half and it's not taking forever to warm up, you don't have a problem.
If it stays cold for too long, the t-stat might be stuck open, preventing the car from warming up and keeping you in a rich warmup condition.
Old Jan 22, 2008 | 10:42 AM
exotik4doorcivic's Avatar
Default Re: (thewrai6th)
mine doesnt go to half until i drive for an hour
i only work 2 miles from my house so im never able to hit vtec because it never goes above C
it might be because of the full core radiator instead of the half?
Old Jan 22, 2008 | 10:48 AM
thewrai6th's Avatar
Default Re: (exotik4doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">it might be because of the full core radiator instead of the half?</TD></TR></TABLE>
Nope, your thermostat should be closed until you warm up, so the amount of fluid in the radiator is not an issue.
Old Jan 22, 2008 | 11:05 AM
98BabiGs-T's Avatar
Mine actually sits bout 1/8 or 1/10 below the "C" and after driving 20 minutes+ it goes to the 1/4th mark and pretty much stays there even on long road trips (3/4 hours before pit-stopping/rest).
Old Jan 22, 2008 | 03:16 PM
all-mtr-teg's Avatar
Default Re: (98BabiGs-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BabiGs-T &raquo;</TD></TR><TR><TD CLASS="quote">Mine actually sits bout 1/8 or 1/10 below the "C" and after driving 20 minutes+ it goes to the 1/4th mark and pretty much stays there even on long road trips (3/4 hours before pit-stopping/rest).</TD></TR></TABLE>
Both my gsr's are the same way.
Old Jan 22, 2008 | 03:31 PM
Audiojb's Avatar
mine stays about 1/3-1/2 at idle then on C while driving. any idea why?
Old Jan 22, 2008 | 03:51 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: (Audiojb)
you also have to look at what time of year it is. the air is way colder. mine was barely breaking into the area above the "c" so i replaced the thermostat. if i let it warm up just idling, it will increase to just shy of halfway. in all my honda's i have ever owned, just shy of halfway is where it always stays.
btw, napa thermostat gasket suck ***, it will leak like a mo'fo, get a oem honda one.
Old Jan 22, 2008 | 05:45 PM
Kmlnd24's Avatar
My Teg had a bad thermostat and it took for ever to warm up.. but when i replaced it stays a little bit less than half.
CleanR
Sep 14, 2007 08:40 AM
KingKash420
Northeast (Sales)
Feb 9, 2006 10:48 AM
PnoyJeff
Oct 6, 2005 06:25 PM
VTECsound
20
Jan 9, 2005 07:23 PM
Andyb22g
Nov 16, 2004 07:18 AM
