rsx 2nd gear grind!!!
ok well i just got my race header on like 2 days ago now i have to take it back off cause my car has to go back to the dealship to get fixed cause i have no 2nd gear Acura should stop BSin around and finally make this a recall!!!!
Help Out and Sign the petiotion if u feel acura should make this a recall and finally fix our trannys!!!!!
http://www.petitiononline.com/....html <<<<<
Modified by iVteCmMdc5 at 9:28 PM 1/21/2008
What are you guys doing to the tranny to grind gears? I am reasonably hard on mine and it has only grinded due to my error, not on it's own. I have a hard time getting it in to go into 1st unless I am moving less than 5mph, but no grinds. BTW, I change tranny fluid every 5K or so.
ok good so im not the only one having these prombs there r others out there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnclaunch »</TD></TR><TR><TD CLASS="quote">What are you guys doing to the tranny to grind gears? I am reasonably hard on mine and it has only grinded due to my error, not on it's own. I have a hard time getting it in to go into 1st unless I am moving less than 5mph, but no grinds. BTW, I change tranny fluid every 5K or so.</TD></TR></TABLE>
maybe u just got lucky and got a good one ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnclaunch »</TD></TR><TR><TD CLASS="quote"> BTW, I change tranny fluid every 5K or so.</TD></TR></TABLE>
That's a complete waste... Tranny fluid can go 50k+ before 'needing' to be changed....
It really can go the life of the car in most cases...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis »</TD></TR><TR><TD CLASS="quote">
It really can go the life of the car in most cases...</TD></TR></TABLE>
yah i was thinking the same thing usually tranny oil can last some time !
I have heard that. However, I am more of a "safer than sorry" person and I'll tell you that I have not had the tranny issues that I have heard others talk about and I know of another Honda-Tech-er that changes his tranny fluid often and he notices no grinds. Might be something to it.
2x...switching tranny fluid is dangerous anywaii =/...
