Cylinder bore & hone question
Old Jan 21, 2008 | 06:10 PM
17's Avatar
17
Default Cylinder bore & hone question
Im finally working on my B16 and I'm working on the block. I took it into a local machine shop (actionautoparts.net) and they wont bore it out 40 over unless I sleeve it. I understand what he's saying but what is recommended bore limit before having it sleeved..for an occasional race on the highway and romp on the engine type driver?
Thanks for any input.
Old Jan 21, 2008 | 06:52 PM
Aquafina's Avatar
Default Re: Cylinder bore & hone question (17)
I only go .5mm (.020") over.
Old Jan 22, 2008 | 10:46 AM
Darton's Avatar
If you plan on making any type of power on this motor it is safer to sleeve the block. Even going with a simple flanged sleeve will be safer than trying to bore out .040 of a stock block. This will make the stock liner extremely thin.
Old Jan 22, 2008 | 10:50 AM
ej1252's Avatar
i would just bore it to 82mm thats the max for stock sleeves anyways
Old Jan 22, 2008 | 11:26 AM
iKhmaiFoSho's Avatar
Default Re: Cylinder bore & hone question (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">I only go .5mm (.020") over.</TD></TR></TABLE>
x2, and any larger i would defintely get the block sleeved and your options are limited to aftermarket pistons/rings but on the plus side you can always build a b20 bottom-end
Modified by iKhmaiFoSho at 3:36 PM 1/22/2008
h22killer
Jan 26, 2010 07:25 AM
Falken22
Nov 24, 2006 12:01 PM
igotthaspirit
Nov 13, 2006 03:54 PM
NLR808
Aug 3, 2004 10:17 AM
92 civic VX B18c
23
Jul 12, 2004 10:13 AM
