PCV valve
Old Jan 21, 2008 | 05:20 PM
Homotor's Avatar
Default PCV valve
will the car not start with out a PCV valve??
Old Jan 21, 2008 | 05:25 PM
Mikey3000's Avatar
Default Re: PCV valve (Homotor)
no, it will start.
Old Jan 22, 2008 | 06:09 AM
Homotor's Avatar
Default Re: PCV valve (Mikey3000)
hmm... then i wonder why my car isn't starting... is it possible that if the vacuums aren't hookd up properly that it would cause the vehicle not to start? because i cannot figure out what it is, im gettin spark and alll the fuel is running through the enginee, the car turnsover and seems like its wanting to start... hmmm i don't knoww anyone have any idea?
Old Jan 22, 2008 | 06:20 AM
Mikey3000's Avatar
what kind of work did you do to it?
Old Jan 22, 2008 | 06:33 AM
Homotor's Avatar
well it originally had the b18a but we pulled that out and dropped it in my brothers ef and now im putting a b18b in it which is a obd1 but everything has been converted to obd0 injectors, intake mani, wire harness, and distributor. im sorry i forgot to mention that it is a 91 integra, there are also one or two hoses im not sure on where they connect
Old Jan 22, 2008 | 06:35 AM
Mikey3000's Avatar
is cam and ignition timing set properly?
Old Jan 22, 2008 | 07:04 AM
Homotor's Avatar
everything should be fine, because before i swapped the engine into the teg it was in my eg and it was running fine, although it would stop at 3000rpm as if it had a rev limiter but i dont know if that ahs to do with anything?
Modified by Homotor at 8:17 AM 1/22/2008
Old Jan 22, 2008 | 07:13 AM
Mikey3000's Avatar
ok can u post a pic of the 2 hoses that you don't know where they go?
Old Jan 22, 2008 | 08:17 AM
Homotor's Avatar
yeah im goin to have to look for my camera when i get off of school
Old Jan 22, 2008 | 04:25 PM
Homotor's Avatar
Modified by Homotor at 6:16 PM 1/22/2008
Old Jan 22, 2008 | 04:42 PM
Mikey3000's Avatar
i dont know what the 2 first pictures are but in the last picture, the left most circle is the Fast Idle Thermo Valve (FITV). that nipple needs a coolant source. the other 2 circles on the same pic are the Idle Air Control Valve (IACV). that also needs a coolant source. i believe the IACV goes to the thermostat housing.
Old Jan 22, 2008 | 06:09 PM
Homotor's Avatar
on the first pic i need to kno where all those vacuum lines connect and on the second pic i dont kno where that hose connects to and on the third pic there was nowhere else i could connect the second circled problem
:::SIRll_EJ1:::
Feb 15, 2010 02:43 PM
haophat
Aug 22, 2004 08:36 AM
benny.ducati
Apr 10, 2004 01:35 PM
Prelude Styl
Mar 14, 2004 11:29 AM
Mr. Softee
Feb 16, 2002 02:15 PM
