timing belt question
i rebuilt my engine.
put the head on. cam shafts, cam caps ect.
set the crank to TDC. loosen tensioner. set both cam gears so the aarows are pointing up.
i set the belt on the exhaust cam first.
double checked the aarows on both gears, then put the belt up on the intake gear.
tighten the tensionher.
is there supposed to be play on the belt still? when i press the belt down between the gears, it goes down about 1/2"
im scared to put the rest of the car together because i think it skipped a tooth..
i tried for 4 hours and had the same result..
how can i resolve this? thanks
98 integra ls
98 integra ls
Check this link:
http://www.c-speedracing.com/h...t.php
You need to rotate the crank to set the tension.
Rotate the crank counter clockwise until you move the cams about 3 teeth. Then tighten the tensioner. If it is still lose you can get a long screw driver and push on the tensioner to tension the belt. Dont do it too tight though.
Mine is actually too tight right now and i am getting a whining noise coming from the belt.
^ thanks.
i couldnt find that info anywhere in the helms.
hopefully i can get this finished tomorrow. THANKS A LOT
Actually..you live kinda close. If you have trouble just shoot me a pm and maybe i can swing by and help you. you are in hb right? carson is a little far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower »</TD></TR><TR><TD CLASS="quote">Actually..you live kinda close. If you have trouble just shoot me a pm and maybe i can swing by and help you. you are in hb right? carson is a little far.</TD></TR></TABLE>
yea border of hb/fv.
my friend is coming over after work tomororw and we're gonna try and get it up and running tomororw. ill hit you up if we dont finish tomororw, lol
ok i got my timing belt on.
car runs, bu tthe idle is low.
and the coolant resv starts to steam when the car is warmed up but the temp gauge is pointing at 11 o clock (normal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueUntilDeath.com »</TD></TR><TR><TD CLASS="quote">ok i got my timing belt on.
and the coolant resv starts to steam when the car is warmed up but the temp gauge is pointing at 11 o clock (normal)</TD></TR></TABLE>
use a timing gun.... and play with the dizzy
timing couple still b off.. but u can advance or degree to get it right on the dot
ok i re did the timing belt. the car RUNS but the timing is really off. i fully advanced it for it to idle correctly.
I'm going to drop it off at my dads shop tomorrow and let them deal with it. lol
re do timing belt and vavle adjustment.
Are you sure you did the timing belt right? When the cams are at tdc, the mark on the crank pulley should actually be a little before the marking on the lower timing belt cover.
The reason this happens is because the belt gets the slack pulled out of it before it starts to move the cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower »</TD></TR><TR><TD CLASS="quote">Are you sure you did the timing belt right? When the cams are at tdc, the mark on the crank pulley should actually be a little before the marking on the lower timing belt cover.
The reason this happens is because the belt gets the slack pulled out of it before it starts to move the cams.</TD></TR></TABLE>
i didnt know that about the crank being a lil before the mark on the cover.
the manual said make sure the white mark is matching with the mark on the cover so its at TDC.
I line up the tdc marks on the cams with the aarons pointing up and the groves on the gears pointing towards each other.
i was able to drive it out to the shop this morning. hope to get it back soon. lol
Yes when you first line it all up, everything should be spot on. THe cams should line up perfect and the crank should line up exactly with the timing belt cover.
But when you go to tension the belt and move the crank counter clockwise, the slack gets pulled out making the crank turn a little bit before the cams begin to turn resulting in the pulley marking being a bit ahead of the mark on the timing belt cover.
^ makes a lot of sense now. lol
shop called. they fixed my timing and heater core problem (i pluged the hose into the wrong outlet? iono .hah
purgat0ry
19
Aug 22, 2012 04:27 AM
Just put my engine back together, I look at the timing belt and its loose in between the cam gears??
Thrillhouse
Aug 7, 2004 10:07 AM
