GSR rear brakes on 91 civic?
Old Jan 21, 2008 | 05:12 PM
JustHere4ADay's Avatar
WHEEL Slayer
Default GSR rear brakes on 91 civic?
Well i just wanted to know if year matters? and if the cables would be ok...
Old Jan 21, 2008 | 07:03 PM
WHEEL Slayer
Default Re: GSR rear brakes on 91 civic? (JustHere4ADay)
Old Jan 21, 2008 | 07:08 PM
91EF9hatch's Avatar
DA rear disc brake will work but their cable might be too long.
Old Jan 21, 2008 | 07:16 PM
dr_latino999's Avatar
Years don't matter, and cables are specific in relation to the chassis you are using.
Old Jan 21, 2008 | 07:45 PM
gourley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustHere4ADay &raquo;</TD></TR><TR><TD CLASS="quote">Well i just wanted to know if year matters? and if the cables would be ok...</TD></TR></TABLE>
You can use the GSR brakes.
Use your stock toe adjustment rod.
Use DA Integra e-brake cables for 88-91 Hatch's
Old Jan 21, 2008 | 08:30 PM
WHEEL Slayer
Default Re: GSR rear brakes on 91 civic? (gourley)
i think the cable is from a DC
Old Jan 21, 2008 | 09:29 PM
Eg2Project's Avatar
what is needed for a swap like this?
Old Jan 22, 2008 | 05:10 AM
CRX Toad's Avatar
Default Re: (Eg2Project)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg2Project &raquo;</TD></TR><TR><TD CLASS="quote">what is needed for a swap like this?</TD></TR></TABLE>
For you to search/read https://honda-tech.com/zerothread/1508680
Old Jan 22, 2008 | 08:42 AM
WHEEL Slayer
Default Re: (CRX Toad)
CRX Toad... would the cables matter? because its comming off a DC...
Old Jan 22, 2008 | 09:33 AM
1320whtrex's Avatar
Default Re: (JustHere4ADay)
You can use the same DC cables, but they are a little bit longer. You will just have to find space to tuck them away somewhere. I am using the full front and rear suspension from a 94-01 Integra
Old Jan 22, 2008 | 09:51 AM
WHEEL Slayer
Default Re: (1320whtrex)
good thats what i wanted to hear!
Old Jan 22, 2008 | 09:57 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320whtrex &raquo;</TD></TR><TR><TD CLASS="quote">You can use the same DC cables, but they are a little bit longer. You will just have to find space to tuck them away somewhere. I am using the full front and rear suspension from a 94-01 Integra</TD></TR></TABLE>
And you can align your car properly?
I thought neither the front nor rear spindles / trailing arms would work right?
Old Jan 22, 2008 | 05:39 PM
WHEEL Slayer
Default Re: (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">
I thought neither the front nor rear spindles / trailing arms would work right? </TD></TR></TABLE>
more info...
Old Jan 22, 2008 | 09:53 PM
1320whtrex's Avatar
I had a camber kit installed on the front and the rear did not need anything done to it. Took it to get an alignment and they took care of everything... I am using the rear trailing arm with the crx lower control arm. No problems..
Old Jan 23, 2008 | 04:34 AM
I had a camber kit installed on the front and the rear did not need anything done to it. Took it to get an alignment and they took care of everything... I am using the rear trailing arm with the crx lower control arm. No problems..</TD></TR></TABLE>
Holy ****. I kept getting mixed responses on that back in the day, I had a great deal on GSR discs a couple years back. Dammit.
Time to keep looking again. I need bigger brakes, and I'm tired as **** of drums.
Old Jan 23, 2008 | 08:15 AM
EL Vap133's Avatar
Rears work fine, they are the same trailing arm.
Fronts are the problem, although some people have made the 92-00 style knuckles fit, doing God knows what, your best bet is going with the 90-93 Integra knuckles for your 88-91 Civic/CRX.
Old Jan 23, 2008 | 11:09 AM
MagnaniEG6's Avatar
Default Re: (EL Vap133)
Does it matter if the rear disc are ABS?
Old Jan 23, 2008 | 07:14 PM
1320whtrex's Avatar
Default Re: (MagnaniEG6)
Doesn't matter at all..
Old Jan 24, 2008 | 03:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Fronts are the problem, although some people have made the 92-00 style knuckles fit, doing God knows what, your best bet is going with the 90-93 Integra knuckles for your 88-91 Civic/CRX. </TD></TR></TABLE>
Thanks Vap. I'll try to find a set of those with better bushings then, kid wanted $100 for some that were shot.
Time to go junkyard hunting in 20 degree ice. Woo hoo.
I was under the impression only the DA rear arms would work before, although I'm not sure why. I'm happy with the front, I just like the ease of upkeep on pads.
Old Jan 24, 2008 | 05:22 PM
97_civickid's Avatar
gotta use your lower control arms if you didnt know...
HondaHeddie
Mar 15, 2008 11:26 AM
tekstyle
Dec 10, 2007 01:40 AM
philosofy1
May 31, 2007 04:07 PM
Vcastro
Mar 30, 2007 10:11 AM
hondaefhatch89
Dec 12, 2005 04:47 PM
