Spoon: 4pots & sw388s
Old Jul 1, 2002 | 02:47 PM
Mario's Avatar
Default Spoon: 4pots & sw388s
As some of you may have already know, Spoon 4pot calipers will not clear their 15" +42mm offset wheel (the only offset available in 5x114.3 & 15").
If other people say different, they're wrong.
So I was originaly told by AJ-Racing that an 8mm spacer would be needed. Then a little later on they said 7mm. However hard I tried, I was not able to readily find any spacers with either of those two widths. And not wanting to use cheap PepBoys spacers I was pretty much stuck
So I had a 3mm generic spacer lying around the house, and picked up a pair of 5mm H&R spacers from Travis "ITR231". And together they combine for a total of...(finger counts the numbers again)...8mm
Here are the results. After the 8mm spacer(s), the clearance between the caliper and rim (spoke) is about 2~3mm. I probably could have gotten away with a 6mm spacer if I shave the SPOON NISSIN insignia. But who'd want to do that right?
15" RiMs 4 LiFe yO!
Old Jul 1, 2002 | 02:55 PM
Black R's Avatar
25 Year Member
Default Re: Spoon: 4pots & sw388s (Mario)
Just buy a 10mm spacer and have it machined on a lathe to whatever size you want it to be..... if you want it 1 piece that is.....
Old Jul 1, 2002 | 02:59 PM
Tommy_Gunns's Avatar
I find it funny that their own rims can't clear their own brakes.
15" RiMs 4 LiFe yO!
Hell yeah, 15" ownz!
Old Jul 1, 2002 | 03:02 PM
Willard's Avatar
Default Re: Spoon: 4pots & sw388s (Tommy_Gunns)
I do also.
Will
-who loves 15" rHyMs
Old Jul 1, 2002 | 03:04 PM
Mike M's Avatar
Founding Member
Mario, you have more room between your caliper and rim than I do, and I have the 16"
Old Jul 1, 2002 | 03:06 PM
norice's Avatar
Probably because they make neither.
Old Jul 1, 2002 | 03:29 PM
Cosworth's Avatar
Default Re: Spoon: 4pots & sw388s (norice)
That looks great... but, I would rather run different 15" rims than having to use spacers.
Old Jul 1, 2002 | 03:40 PM
Jackson's Avatar
Haha, awsome. You finally got them on.
Old Jul 1, 2002 | 11:07 PM
evil vapor's Avatar
Default Re: Spoon: 4pots & sw388s (Jedi Master)
perfect...8mm is perfect, don't go less than that. And there is nothing wrong with spacers. Go to any race and you're bound to find cars running wheel spacers.
Old Jul 1, 2002 | 11:21 PM
_unknown_'s Avatar
Default Re: Spoon: 4pots & sw388s (VTEC CX)
Good job Mario. That is the same dilema I was facing. Now it is cleared up!!!
Old Jul 1, 2002 | 11:30 PM
Tweakmeister's Avatar
Default Re: Spoon: 4pots & sw388s (garth)
Old Jul 2, 2002 | 12:40 AM
beeboyee's Avatar
Default Re: Spoon: 4pots & sw388s (Tweakmeister)
good stuff mario
Old Jul 2, 2002 | 12:58 AM
eg_nezay's Avatar
they want you to buy the more expensive 16's
marcdem86
Jun 30, 2009 09:40 AM
K20EF8
14
Oct 18, 2006 03:20 PM
purplehazek4
Sep 9, 2002 03:42 PM
jeff652
Sep 20, 2001 01:23 PM
