GSR Head with B16 Block
Old Jan 21, 2008 | 09:37 AM
b18bc3po's Avatar
Default GSR Head with B16 Block
One of my buddys was talking to me about this combo. I tried to research it but found hardly anything about the topic. From what he was saying if i use a b16 bottom end with gsr internals and a ls crank it would pretty much be a 1.9? I am afraid to do this becuase there isnt much information about it compared to the ls/vtec. I plan to do everything but sleeve and boring and boost later, but any input would be greatly appricated. Thanks Erik.
Old Jan 21, 2008 | 09:41 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: GSR Head with B16 Block (b18bc3po)
B16A blocks are shorter than B18C# and B16B blocks. I'll guess that the longer stroke internals in a B16A block would not work.
Old Jan 21, 2008 | 11:30 AM
DA_9's Avatar
Default Re: GSR Head with B16 Block (Dogginator)
I'd do a b16 head and gsr block.....poor man type r. This chick up here in Bellevue owns a del sol with that set up and kept up pretty evenly wit my somewhat built ls vtec.
Old Jan 21, 2008 | 05:59 PM
b18bc3po's Avatar
Default Re: GSR Head with B16 Block (DA_9)
Yeah thats what my buddy is in the process of doing right now, the reason for asking about the GSR head is because he is giving me a really good deal on it.
Old Jan 21, 2008 | 06:02 PM
jdmboy91's Avatar
hey i know this is stupid but umm i new to honda-tech how do u post pics and fourms
Old Jan 21, 2008 | 06:07 PM
Micha's Avatar
FAILWGN
Default Re: GSR Head with B16 Block (jdmboy91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboy91 &raquo;</TD></TR><TR><TD CLASS="quote">hey i know this is stupid but umm i new to honda-tech how do u post pics and fourms </TD></TR></TABLE>
Host your pictures somewhere like http://www.photobucket.com and use the [img] link to put them on your posts.
Old Jan 22, 2008 | 04:52 AM
b18bc3po's Avatar
Default Re: GSR Head with B16 Block (micha)
So does anyone know anything about this setup? I learned that the b16a block is shorter about 7-8mm.
Old Jan 22, 2008 | 05:31 AM
Micha's Avatar
FAILWGN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bc3po &raquo;</TD></TR><TR><TD CLASS="quote">So does anyone know anything about this setup? I learned that the b16a block is shorter about 7-8mm.</TD></TR></TABLE>
This means if you use a 89mm crank... the top of your pistons will stick out of your block about 4-6mm.
I can't think of who does it... but there is a company that will add a piece to the top of your block to make the cylinders taller.
Ask in the natural aspiration forum.
Old Jan 22, 2008 | 05:41 AM
b18bc3po's Avatar
I can always go with a b16b block too though, i think its the same. As far as putting gsr internals and an ls crank in the b16 would it be worth it?
Old Jan 22, 2008 | 07:35 AM
DAmnquickDA's Avatar
no
Old Jan 22, 2008 | 08:36 AM
Rickdrizzle's Avatar
just get a gsr block with the head and be done with it.
Old Jan 22, 2008 | 09:03 AM
b18bc3po's Avatar
Default Re: (Rickdrizzle)
yeah true but I also want the torque from the ls too, and b18b block go cheap all day long, so once i put the money into ls/vtec it will be the same as buying a GSR block prolly.
Old Jan 22, 2008 | 09:15 AM
Micha's Avatar
FAILWGN
Default Re: (b18bc3po)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bc3po &raquo;</TD></TR><TR><TD CLASS="quote">yeah true but I also want the torque from the ls too, and b18b block go cheap all day long, so once i put the money into ls/vtec it will be the same as buying a GSR block prolly.</TD></TR></TABLE>
did you get my PM?
Old Jan 22, 2008 | 09:41 AM
There were some debates on another forum about the gsr block and ls block. I suppose the displacement on the Ls block is a bit bigger, but the 89mm isn't as rev friendly as the 87mm gsr block. Again, this is what I was reading about and I'm not 100% true if it's correct or not.
Old Jan 22, 2008 | 10:00 AM
b18bc3po's Avatar
Default Re: (micha)
Maybe i have no idea even how to pm someone on here, Its nothing like any other forums i get on.
Edit nvm its under the IM lol
Old Jan 22, 2008 | 10:52 AM
fadedgsr's Avatar
This wont work , i tried this last month, awaste of money and time.
Old Jan 22, 2008 | 10:56 AM
b18bc3po's Avatar
Default Re: (fadedgsr)
what the gsr/ b16 block? what here the problems and what did you do instead?
Old Jan 23, 2008 | 10:33 AM
DA_9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle &raquo;</TD></TR><TR><TD CLASS="quote">I suppose the displacement on the Ls block is a bit bigger, but the 89mm isn't as rev friendly as the 87mm gsr block.</TD></TR></TABLE>
No your right, and the reason Ls motors blow is because dumb kids rev it to 9k on stock rods... APR rods for about 100 bucks or so solve that problem. You can build a lsvtec for like 1900 or less if you have a GSR head. The price includes Tuning in most places, a b16 lsd tranny, oil kit, pumps, belts, etc. Its a good package.
eastbayg
Sep 10, 2009 08:42 PM
boostedefhatch
Apr 14, 2009 06:26 PM
Jintegragsr97
Jul 11, 2007 09:22 AM
JspecCivic94
Oct 25, 2005 06:26 AM
this name is gone
Nov 9, 2004 01:22 PM
