B16, siRII IACV?
Old Jan 21, 2008 | 07:25 AM
drives a vtec's Avatar
Default B16, siRII IACV?
Hey everyone,
I've got a Del Sol with am obdI JDM siRII(B16) swapped into it and I'm having some issues locating what IACV will fit. I know the connectors are interchangeable, but the IACV that's on the intake is significantly longer than others I've encountered. I tried to use a OBDII B16(Civic Si) IACV, but the bolt pattern was off. I also compared it with one from a Z6 on a friends hatch, still no luck.
So if anyone can help me, that'd be great.
-Josh
PS. I'll have measurements posted up a little later.
Old Jan 21, 2008 | 07:37 AM
Default Re: B16, siRII IACV? (drives a vtec)
That's the motor, if anyone needs clarification.
Old Jan 24, 2008 | 11:59 AM
Bump
Old Jan 24, 2008 | 07:39 PM
tnez's Avatar
what about the IAC from the USDM b-series del sol? isnt that an obd1 b series?... its the dels sol vtec, I believe?
Old Jan 25, 2008 | 10:07 AM
92civicx's Avatar
Default Re: B16, siRII IACV? (tnez)
i know that theirs 2 different iacv for b16's. I would go for del sol vtec also
Old Jan 25, 2008 | 11:11 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: B16, siRII IACV? (92civicx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicx &raquo;</TD></TR><TR><TD CLASS="quote">i know that theirs 2 different iacv for b16's. I would go for del sol vtec also </TD></TR></TABLE>
x3
Old Jan 25, 2008 | 06:03 PM
tnez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drives a vtec &raquo;</TD></TR><TR><TD CLASS="quote">Hey everyone,
-Josh
PS. I'll have measurements posted up a little later.</TD></TR></TABLE>
I only helped you cause you have a kool name, haha jk... but seriously, if the del sol vtec doesnt work... try the jdm eg(92-95) SiR/SiR2 hatchys.. those are also obd1 b16's
GL man...
94delsol6428
20
Oct 2, 2012 07:10 PM
allmotorEG-SI
22
Dec 31, 2008 09:17 AM
zigg_1311
Aug 12, 2007 10:48 AM
FormulaGSR
12
Feb 26, 2005 06:31 PM
mooseknuckle
Apr 3, 2002 08:27 PM
